Overall: 7911
Visitors: 159
Total: 159
89: Home
94: Home
99: Home
117: Home
My Other Vice...
Go to page Previous  1, 2, 3 ... 12, 13, 14, 15, 16, 17  Next
PostPosted: Sat Mar 19, 2011 12:11 am    Post subject: Re: My Other Vice...1st Start Video
Lol I have been following this thread from the start. I love older imports and you have one of my favorites(and your doing it right which is rare today)
It's awesome to hear its running and good luck with the rest of the build. I will own my 240z at one point and I am constantly looking for one. Oh some day.
Keep up the good work I can't wait to see it "finished"(parentheses because with cars the project is never finished)
PostPosted: Thu Apr 21, 2011 2:08 pm    Post subject: Re: My Other Vice...1st Start Video
Got my new Turn Signals in. After sanding the lenses with 400 then 800 and then polishing on the bench polisher the lenses look almost new. The housings were lightly sanded with 220 then prayed with charcoal metallic and low gloss black trim paint to bring them back to life. Wired them up with new bulbs and now I have turn sigs!
Sorry it's an iPhone pic in the dark Sad
Items left to finish:
-Reinstall carbs and balance, (i.e. Smooth out the idle, waiting on new pilot screws)
-get brakes working(waiting on SS brake line set)
-wire up reverse lights(mine was an automatic so having trouble locating reverse wires to hook to W50 trans)
-reinstall wipers(need to recut the motor hole)
-finish carpet install
-finish recovering a-pillars
-install all glass
PostPosted: Thu Apr 21, 2011 2:30 pm    Post subject: Re: My Other Vice...1st Start Video
This guy is coming along nicely. You're going to have to put up a vid of you ghost riding it when it's done
PostPosted: Thu Apr 21, 2011 2:33 pm    Post subject: Re: My Other Vice...1st Start Video
don't know about Texas, but NJ has no laws requiring to have back-up lights. the simple idea is to do is to forget about it or even wire a activation switch so that it turns on when you want it. but i know you want to do this right, so my options aren't going to work for you
other than that, looks great.
PostPosted: Fri Apr 22, 2011 10:16 am    Post subject: Re: My Other Vice...1st Start Video
i think here in Texas back up lights are not mandatory...but I don't want to have anything on this car not working. everything has to work or it's just a half-a$$ build....wich I won't have.
on a side note i have been trying to figure out why the engine runs so rough at idle. it smoothes out as you transition to highter RPMS.
turns out the idle mixture pilot hole was plugged. so cyl 3 was getting no fuel at all. plugged with what you ask? the tip of the pilot mixture screw! some jack-wagon cranked the pilot screws in so tight it broke the tip of the needle off in the hole completely plugging it...douche!
yanked the rear carb cleaned it, made new jet cover gaskets and pressed out the broken needle tip. ordered new pilot needle screws, soon as they come in i'm ready to run this again and see how it idles.
PostPosted: Wed Apr 27, 2011 1:05 pm    Post subject: Re: My Other Vice...1st Start Video
got the wiper mechanicals reinstalled. had to cut out the holes for everything since i originally shaved them and welded up the holes. Thank the all mighty for die grinders! I left the driver side cowl access hole shaved and didn't re-open it since it looks better gone.
painted the motor with some rebuilders silver and installed the new washer bottle and bracket.
PostPosted: Wed Apr 27, 2011 2:10 pm    Post subject: Re: My Other Vice...1st Start Video
mmmm windshield wipers
PostPosted: Thu Nov 17, 2011 5:01 pm    Post subject: Re: My Other Vice...1st Start Video
got this running again. snap1 I didn't realize all my pic links are broken now. need to move it all to photbucket and edit the links....that sounds like a pain in the a$4
PostPosted: Thu Nov 17, 2011 6:18 pm    Post subject: Re: My Other Vice...1st Start Video
after your come back "Sister" post, i remembered your car post. any updates?
PostPosted: Sat Nov 19, 2011 3:08 pm    Post subject: Re: My Other Vice...1st Start Video
here is a new video from last night. Timing is a bit better. still think it's running a bit too much advance. but sounding better.
www.youtube.com/watch?...aGikDisoqc
i tried embeding the video but i got frustrated and so you just get a link.
Page 13 of 17
