Visitors: 57
Total: 57
26: Home
33: Your Account
Forums › Buy/Sell/Trade › ICD Gear Forum :: Archives › WTB Valve poppet :: Archived
WTB Valve poppet
enemymaster
PostPosted: Wed May 04, 2011 2:18 am    Post subject: WTB Valve poppet
I have a valve poppet but the problem is that its so worn that the tip got pushed down some and now cant get it out of the valve body. I want to cut it out but before I do I need a nice valve poppet
MuthaFunk
PostPosted: Wed May 04, 2011 3:35 am    Post subject: Re: WTB Valve poppet
Hugh? Do you mean you want a replacement cup seal for your ICD stock Poppit valve? What kind of valve is it? You said it's stuck and your going to cut it out?? Hmm. It's hard to make sense of what you need here.
enemymaster
PostPosted: Wed May 04, 2011 3:50 am    Post subject: Re: WTB Valve poppet
it seem's to be made of copper or some soft metal.The back of the bolt has the rod coming out of it and goes back and hits the valve rod. Where it hits it got worn over long period of use probably. Now it is wider at the tip and cant slide out. The funny thing is in my other ndfs7 it is in 2 pieces so there is no problem. I hope this helps.
enemymaster
PostPosted: Wed May 04, 2011 3:52 am    Post subject: Re: WTB Valve poppet
if you look in the fs7 schematic it is 506020 part number
PostPosted: Wed May 04, 2011 7:43 am    Post subject: Re: WTB Valve poppet
You can also file the outside of the stem a bit and it will come out. Don't get rid of it if you can help it. These eventually break, so keeping a used one will someday pay off for someone!
I will check my parts box for extras but I dont think I have any.
MuthaFunk
PostPosted: Wed May 04, 2011 7:46 am    Post subject: Re: WTB Valve poppet
Ahhh yes. It's for an FS7. I understand now. I thought you were talking about a Bushmaster. * edit. nevermind.
enemymaster
PostPosted: Wed May 04, 2011 12:35 pm    Post subject: Re: WTB Valve poppet
ill only file it it when I find another part. The gun works fine but the bolt doesn't come all the way forward thats all
