Menu: |
User Info |
Donations |
Donate and suport ICDO! |
Forums › Marker Talk › Problem/Tech forum :: Archives › Freestyle valve stem oring :: Archived |
Freestyle valve stem oring Have a problem with your marker? Ask here
View previous topic :: View next topic |
Author |
Message |
viper588 Amateur
Posted: Thu May 19, 2011 1:55 pm Post subject: Freestyle valve stem oring |
Ok guys iv been trying to fab up the new valve tip yet keep running into an issue my current issue is that the gun sill work great for about 25 shots, then air will dump down barrel. Wehn i disassemble the bolt the valve stem oring is out of the groove and around the valve stemup by the tip of the bolt. Ever heard of this happeneing? I first assumed i made the valve tip a little too large but measureing the original valve tip it is still a little bit smaller. Any thoughts or help would be appreciated! Thanks!
Back to top |
p8ntballdad ICDO Supporter
Posted: Thu May 19, 2011 2:43 pm Post subject: Re: Freestyle valve stem oring |
Are you using the proper o ring? 04/05 Freestyles use -006 and FS-7s use -007 90 durometer urethane o rings.
_________________ ICD-O Feedback
Bonebrake Bushmaster / Fishmill Bushmaster / "Rusty" FS8 / 05 NDFS / Dust green MI BKO / 2 Alleycats
05 Proto Matrix / 06 Ego / OG Quest / 98 Cocker with CCM pump kit |
Back to top |
viper588 Amateur
Posted: Thu May 19, 2011 4:02 pm Post subject: Re: Freestyle valve stem oring |
p8ntballdad wrote: |
Are you using the proper o ring? 04/05 Freestyles use -006 and FS-7s use -007 90 durometer urethane o rings. |
Sorry, forgot to mention its for an hr1 but yes using 008 oring for stem.
Back to top |
viper588 Amateur
Posted: Thu May 19, 2011 6:00 pm Post subject: Re: Freestyle valve stem oring |
Ok well a little update. Oring stays on without any issues at 300psi. If reg is raised to 350 pops the oring off. Hopefully i will be able to get a decent FPS without increaseing the reg or with little increase without causeing issues with that oring. I will have to do some testing when i go saturday.
Still welcome to any suggestions or insight as too why the higher pressures would cause the oring to pop out when the valve diameter is a little smaller than the proper one! Thank You!
Back to top |
Posted: Thu May 19, 2011 6:40 pm Post subject: Re: Freestyle valve stem oring |
Are you using 90 durometer urethane o rings?
Back to top |
viper588 Amateur
Posted: Thu May 19, 2011 10:52 pm Post subject: Re: Freestyle valve stem oring |
Are you using 90 durometer urethane o rings? |
Its currently a buna 70. In maing the valve tip kept drilling it a little larger each time till it worked and all my urethanes got pinched and sliced in half so had to move to the bunas. Didnt occur to me that i still have the buna in there! Ill pick up some urethane tomorrow and try again Thanks for the suggestion!
Back to top |
maloneoni Man with no name
Joined: Feb 06, 2008 Posts: 6365 Location: livermore, ca
Posted: Fri May 20, 2011 4:44 am Post subject: Re: Freestyle valve stem oring |
This. The 70 bunas jam in there pretty bad. I experienced this on the FSP that I had so much fun with.
cs900 wrote: |
a can opener is a good alternative to a sp on off. |
63VDub wrote: |
I see potential for a CO2 operated tattoo gun... |
Beating plowshares into swords. |
Back to top |
ThcGunSmoke Moderator
Joined: Apr 09, 2006 Posts: 967 Location: Pemberton, British Columbia
Posted: Fri May 20, 2011 11:44 am Post subject: Re: Freestyle valve stem oring |
try 90 duro vion if ura is giving you slicing troubles
Back to top |
viper588 Amateur
Posted: Fri May 20, 2011 7:40 pm Post subject: Re: Freestyle valve stem oring |
Well thanks guys! Got some urethanes today and bumped the PSI back up and no longer have any issues! I have yet to chrono or use in game but emptied what was left of my tank and all seems good! I will find out tomorrow when i play and she is problem free since the original HR-1 valve tip broke in half. Thanks again for the help!
Also is there an advantage to the viton orings gunsmoke?
Back to top |
viper588 Amateur
Posted: Sat May 21, 2011 7:27 pm Post subject: Re: Freestyle valve stem oring |
Ok so gun worked great with the exception of velocity. I was not able to get the velocity above 240FPS. We were indoors at a small field where its 260FPS so it wasnt too big a deal this time. I thought it was a little wierd cause if i had the HPR at 320 i shot like 235-240. If i turned it up to 380 it still shot 235-240. I adjusted the dwell and changed from 9-18 and at all of them shot at about 235-240FPS. i thought that it was a little strange that almost anything i did with HPR or dwell left me with the same 240FPS. I dont see how the new valve tip i have would cause this issue but im no expert.
Also i had an idea when i got home. If i was to remove the rear oring on the HR-1 bolt wouldnt it then function like the stock non-HE bolt? I thought that since the HR-1 shuts off air when in forward position that removing the oring would allow more air and allow dwell to help with velocity. I realize its a "downgrade" in efficiency but figure i would have a fully operation freestyle while i tech it. thanks for all the help so far!
Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
Photo Gallery Pics... |
Forums scroll Last posts |
Last 10 Forum Messages |
