Latest: major_movit
New Today: 1
Overall: 7915
Visitors: 72
Total: 72
09: Home
33: Top
68: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › BKO Woes & board questions :: Archived
Norbinc
PostPosted: Tue May 24, 2011 8:05 pm    Post subject: BKO Woes & board questions
Okay put the one together from parts,decided to use 22 pin bushy brd,used diagram,no luck,can get led to light,but no click from noid,is the stock noid 5 volts? I do have a power supply I can hook up and see if it clicks.I wired the first 2 to noid next 2 upper - then + to switch,switch to led then to lower,trigger wired to the next 2.# 7 down (plugged) Is this all I need?
Take you kids paintballing its the only time you can shoot them and get away with it.
Silver Karnivor:
s1083.photobucket.com/...030224.jpg
icdnoob
PostPosted: Tue May 24, 2011 9:01 pm    Post subject: Re: BKO Woes
ill let one of these other guys help diagnose. if you need a noid i have one that works for sure. i know you have to have the board in to hear the noid click. i have a harness that needs the on/off resoldered and i used the 9 volt adapter for another project. you would have to do a bit of work to it but if you need that ill just mail it to you. pm about either one
"champagne for my real friends, and real pain for my sham friends"
Im always looking for old school all americans
Norbinc
PostPosted: Fri May 27, 2011 10:33 pm    Post subject: Re: BKO Woes
Okay went back and wired it 12 pin,noid clicks,so what am I missing on the 22 pin?(that was with stock board)Could 22 pin bushy brd be bad?
Silver Karnivor:
Norbinc
PostPosted: Tue May 31, 2011 5:34 pm    Post subject: Re: BKO Woes
Okay just about given up on getting 22pin bushy brd to work,anyone with any ideas would help,thanks
Silver Karnivor:
Norbinc
PostPosted: Wed Jun 01, 2011 8:35 am    Post subject: Re: BKO Woes & board pin outs
I looked through the diagrams and sticky's still cant find pin out for stock F/S vertical board.Also is this a nox reloaded brd? It says icd on it w/either 8300 or 8500 cant remember. I can try to take some pics tonite,busy time for greenhouses(12-14hr days),thanks.
Silver Karnivor:
PostPosted: Thu Jun 02, 2011 4:04 am    Post subject: Re: BKO Woes & board pin outs
All 12 pin harnesses and therefore pinouts are the same. The only thing that would change is the removal of the trigger switch wires for board with onboard switches.
Norbinc
PostPosted: Thu Jun 02, 2011 8:09 am    Post subject: Re: BKO Woes & board pin outs
Okay,then that answers that,board no good.Now going to try other boards to see if I can get them to work.Do we have any employees of ICD still on here?Maybe I could get them to research older ICD boards sure would like to repair these 2. Thank again.
Silver Karnivor:
Norbinc
PostPosted: Sun Jun 05, 2011 11:51 am    Post subject: Re: BKO Woes & board questions
I took 63vdub's advice plugged up a stock ICD9500 board in the BKO project and it works(w/either trigger switch) what board is this called and is there adjustments to it? It seems like the debounce or something is set wrong,if I pull trigger slowly it fires fine but if I speed up it sounds like its going full auto.
Silver Karnivor:
