Latest: NisaDisco
Overall: 7919
Visitors: 82
Total: 82
82: Home
Forums › General › Paintball talk :: Archives › reball question :: Archived
reball question
Tzarector
PostPosted: Wed Jun 08, 2011 5:02 pm    Post subject: reball question
Are reballs made to be the same weight as a real paintball? can i use it to chrono a gun in the backyard? also, where can i buy reballs for cheap? any info on this is greatly appreciated.
PostPosted: Wed Jun 08, 2011 5:03 pm    Post subject: Re: reball question
I used reballs to tune guns in the house, but I don't recall if the velocity went up or down when I switched to paintballs.
As far as a cheap place to find them, they can be had relatively cheaply on PBN.
Tzarector
PostPosted: Wed Jun 08, 2011 5:22 pm    Post subject: Re: reball question
found a bag of 100ct reball on ansgear.com for 15 bux. not bad. some guy on pbn was trying to sell 1 pod for $25.
Supergyro
PostPosted: Wed Jun 08, 2011 5:48 pm    Post subject: Re: reball question
I've got reballs, but I try to run them at about 240fps because they'll dent otherwise.
Haters, gon' hate.
My MCB Feedback
WTB Bushy SCM III
PostPosted: Wed Jun 08, 2011 9:02 pm    Post subject: Re: reball question
there are "real" reballs and "fake" reballs. hence why someone could sell a pod for $25. reballs or any reusable paintball can be chrono'd. they are similar in weight and shape, hence force feeding loaders can work.
Tzarector
PostPosted: Wed Jun 08, 2011 9:16 pm    Post subject: Re: reball question
ah. makes sense. a real 140ct go for 50 bux on pbstore.com
kruppy
PostPosted: Thu Jun 09, 2011 12:15 am    Post subject: Re: reball question
I have found the reballs and the knock offs are smaller in diameter, small enough that SP actually makes a new insert now just for reballs that is smaller diameter then everything else. If you want to use reballs to chrono test then i would recommend that bore if you have a freak kit. Otherwise you'll get it close but likely still do some tweaking when it comes field time.
Reballs, as well as all the others i have seen recommend a lower FPS then with paintballs, although i forget the number. I believe this precaution is used only for the purpose to keep injuries down when actually used as projectiles in games.
2k1 MacDev Sonic Autococker
- E-Bladed (undrilled)
- Shocktech Feedneck
- 15* Asa
Tzarector
PostPosted: Thu Jun 09, 2011 1:52 am    Post subject: Re: reball question
Good info kruppy. Thanks!
Nike Air Max 90 zu seiner
asics scarpe basso prezzo
basket adidas femme pas cher
nike air max 2090 hombre
