Latest: Osweiler
Overall: 7925
Visitors: 361
Total: 361
01: Home
62: Your Account
83: Home
85: Home
91: Home
98: Home
107: Home
109: Home
110: Home
114: Home
120: Home
127: Home
133: Home
138: Home
143: Home
157: Photo Gallery
176: Home
178: Home
180: Home
187: Home
191: Home
199: Photo Gallery
209: Photo Gallery
211: Home
215: Home
221: Photo Gallery
227: Photo Gallery
230: Photo Gallery
233: Home
234: Home
235: Home
239: Photo Gallery
246: Home
249: Home
253: Photo Gallery
257: Forums
262: Forums
263: Home
265: Forums
267: Forums
268: Photo Gallery
270: Home
271: Photo Gallery
272: Forums
273: Forums
274: Forums
275: Forums
277: Forums
279: Forums
280: Forums
281: Forums
283: Photo Gallery
285: Forums
286: Photo Gallery
287: Forums
288: Forums
289: Forums
290: Forums
291: Forums
292: Forums
293: Photo Gallery
294: Forums
295: Forums
296: Forums
297: Forums
298: Photo Gallery
299: Forums
300: Forums
301: Forums
302: Forums
303: Forums
304: Forums
305: Forums
306: Forums
307: Forums
308: Forums
309: Photo Gallery
310: Home
311: Forums
312: Forums
313: Forums
314: Home
315: Forums
316: Photo Gallery
317: Forums
318: Home
319: Photo Gallery
320: Forums
321: Forums
322: Home
323: Forums
324: Forums
325: Forums
326: Forums
327: Home
328: Forums
329: Forums
330: Forums
331: Forums
332: Forums
333: Photo Gallery
334: Forums
335: Home
336: Forums
337: Photo Gallery
338: Forums
339: Forums
340: Forums
341: Forums
342: Home
343: Forums
344: Forums
345: Forums
346: Forums
347: Forums
348: Forums
349: Forums
350: Photo Gallery
351: Photo Gallery
352: Forums
353: Photo Gallery
354: Forums
355: Photo Gallery
356: Forums
357: Photo Gallery
358: Forums
359: Photo Gallery
360: Forums
361: Forums
Go to page 1, 2, 3, 4, 5, 6  Next
L3G0
PostPosted: Sun Jul 17, 2011 10:34 pm    Post subject: Bushmater cycles but doesn't fire
Okay, I read 2 other threads of this calibre and my valve is not upside down, nor is my bolt. Okay so.. the gun gasses up fine. bolt goes back. but when I fire the gun, the bolt only seems to travel quarter or sometimes half of the way of the travel it should. My high pressure reg shows 400PSI and i've reset my LPR multiple times by turning in until it leaks then backing it off 2 turns, I dont' see very much drop on my gauge during cycle.. and it seems like it has full power to everywhere.. but no air comes from the barrel. Im completely stumped! what should i try?
Thanks, Dan
I verified that the ram rod/bolt is not travelling far enough to hit the pin to allow the air to flow and fire the ball.
PostPosted: Sun Jul 17, 2011 10:49 pm    Post subject: Re: Bushmater cycles but doesn't fire
Dan,
First, lower the pressure on your guage to about 200-225 psi. 400 is way too much. Second, turn your lpr in until the solenoid vents and then back out about one half turn. That should get things cycling. If you aren't shooting at those pressures, then we need to know what kind of board you have to see if maybe the dwell is low. Other than that, you need to make sure your ram/bolt assembly moves smoothly. If your bolt sticks anywhere along the travel, that can cause cycling problems.
See what that does and get back with us.
-Colin
L3G0
PostPosted: Sun Jul 17, 2011 11:10 pm    Post subject: Re: Bushmater cycles but doesn't fire
thank you for the reply,
Okay, I did as you said.. I lowered it to 225psi at the HPR guage, turned out the LPR again, the gun is continuing to cycle the same.. only pushes the ram rod/bolt forward quarter to half the actual travel at full speed, repeatedly. I checked my ram rod and bolt movement again... seems fine no sticks tight spots, i even relubed the ram rod a bit.
seems like it doesn't have enough force to push the ram rod forward to hit the pin. If i give it a little tug forward while cycling it (I know.. bad idea) it will cycle but only while tugging a bit during cycling..
Its an un modified BUshmaster B 2 K w/ PDS, Ninja 68/4500 UL (450ish psi).
its automatically turning b 2 k into bushmaster when i submit :/
PostPosted: Sun Jul 17, 2011 11:33 pm    Post subject: Re: Bushmater cycles but doesn't fire
Take the tray off, and see if your solenoid, or solenoid manifold has become obstructed; either with a piece of o-ring or teflon tape or something.
Also, you solenoid gasket might be crushed from over-tightening your noid onto the manifold.
What kind of ASA are you using?
PostPosted: Sun Jul 17, 2011 11:37 pm    Post subject: Re: Bushmater cycles but doesn't fire
Sorry, that's one of my OCD auto correct things.
Have you had this Bushy very long? Have you cleaned and lubed the ram? If you bought it used, it may very well have an aftermarket board in it. At those pressures and with the correct dwell and a lubed ram, there should be no problems. Give us some history and we'll figure it out.
L3G0
PostPosted: Sun Jul 17, 2011 11:44 pm    Post subject: Re: Bushmater cycles but doesn't fire
I will check the solenoid for an obstruction. well I did tighten 1 solenoid screw, and your going to love this story. It will also be the history.
I bought this bushy brand new! in '02 or '03. Guns shows up! SO DOES A BABY XD. Needless to say, the setup was never finished and i haven't had the cash to finish my rig or play up until now. So i ordered my tank/hopper etc. went the first day. Gave the gun a once over for lube/seals, just checking everything. Gun shot beautiful. home, clean, back to box... second time we go.. somehow my hpr vertical asa comes loose and my gun basically fell apart in my hands. used a rental that day.... put the gun back together dry fire it a few times. works great again. went to go to the field today. and it fires but doesnt' shoot paint Sad
EDIT
Oh yea that screw.. since the day i bought the gun it had a rattle in it.. when i dismanteled the gun to fix the vertical asa i found the back right solenoid screw rolling around :/
EDIT AGAIN...
my bottomline ASA is a CP /on off i believe i forget what brand but it works great no problems with it or my macro line.. i opened it up with the macro disconnected to see if i was getting tons of air and i am XD
PostPosted: Mon Jul 18, 2011 12:02 am    Post subject: Re: Bushmater cycles but doesn't fire
Not the dwell then. Sounds just like some ram stick. Or a noid issue.
Is the battery fresh? I bet its the battery.
L3G0
PostPosted: Mon Jul 18, 2011 12:08 am    Post subject: Re: Bushmater cycles but doesn't fire
Brand new battery Razz
ANYWAY, we have some head way Smile I took the 'noid' off. looked very clean not to much lube BUT the little clear oring was well oddly shapped.. so i reformed it, put the noid back on gassed up the gun, reset lpr, and i had blowback XD but my noid is leaking all over the place so i have to see if i can tighten it just a touch more without mucking it up again.. but i be you will recommend a set of new orings wont ya Smile
PostPosted: Mon Jul 18, 2011 12:33 am    Post subject: Re: Bushmater cycles but doesn't fire
check the noid again, as it sounds like you could have put the noid piston in backwards. there should be only a light sheen to the orings, nothing more. except for the valve screw, all the screws should only be tightened to finger tight. the screws don't need to be torqued down.
next, since the gun was new from 02/03, i'm thinking that there is possibly a bad oring in the ram, or lack of lube on the ram itself. this would have caused the slow shot.
also, check the ball detent i it has a cocker detent. too far, and the bolt will bounce off it and not cycle properly.
also, check to make sure that the bolt pin is sitting properly in the ram. the gun could be cycling properly, but if the bolt pin is not seated correctly, it would make the bolt not move, but shoot correctly.
L3G0
PostPosted: Mon Jul 18, 2011 1:04 am    Post subject: Re: Bushmater cycles but doesn't fire
nah the dents are fine, same as the rod and stuff i've check it many times.. you had it right with the noid...
There is 3 things on it when i take it off.. a big oval black oring, at the back, with the clear oring in the middle, which i said it is deformed, and now see its has 2 cracks, and one more small black oring at the front. I just changed the clear one. as i had one.... now i have the lpr basically screwed out all the way, and no matter how tight or loose i put the noid screws it leaks, but when it gets close to sealing it cycles with blow back..
basically I think i just need to get it to seat and seal. correct?
Page 1 of 6
Mike Tomlin implies there is a trong possibilitythe Steelers
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:45:00
Packers stay on offense, add RB A.J. Dillon
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:44:39
For 2nd straight season, Seahawks offense struggling to fly
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:44:12
Chiefs welcome fresh/outdated faces inside of Allen
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:43:58
Run defense issues highlight total breakdown for Saints
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:43:15
Pitch and catch: Round 2 of NFL draft heavy on receivers
Last post by Osweiler in Off Topic on Nov 26, 2020 at 03:42:37
Corridor of Fame QB Jim Kelly suggests checks demonstrate re
Last post by Osweiler in Paintball talk on Nov 26, 2020 at 03:42:15
How do you hit pictures in NBA2K21?
Last post by wfuuopy in Off Topic on Nov 20, 2020 at 01:53:02
RuneScape is Free-To-Play
Last post by wfuuopy in Paintball talk on Nov 20, 2020 at 01:52:09
If You Are Clever About It
Last post by Kingang in Off Topic on Nov 18, 2020 at 10:05:37
