Latest: wfuuopy
Overall: 7924
Visitors: 333
Total: 333
41: Your Account
102: Home
111: Home
155: Photo Gallery
156: Home
162: Home
178: Photo Gallery
180: Home
186: Photo Gallery
188: Home
189: Photo Gallery
193: Photo Gallery
194: Home
203: Photo Gallery
208: Photo Gallery
209: Photo Gallery
211: Photo Gallery
213: Photo Gallery
245: Photo Gallery
248: Home
257: Home
259: Home
262: Forums
263: Forums
267: Forums
271: Forums
272: Forums
273: Forums
274: Forums
275: Forums
277: Forums
278: Home
279: Forums
280: Forums
281: Forums
283: Forums
285: Forums
286: Forums
287: Forums
288: Photo Gallery
289: Forums
290: Forums
291: Forums
292: Photo Gallery
293: Forums
294: Your Account
295: Forums
296: Photo Gallery
297: Forums
298: Forums
299: Photo Gallery
300: Photo Gallery
301: Forums
302: Forums
303: Forums
304: Forums
305: Forums
306: Forums
307: Forums
308: Forums
309: Forums
310: Photo Gallery
311: Forums
312: Forums
313: Forums
314: Forums
315: Forums
316: Forums
317: Forums
318: Forums
319: Forums
320: Forums
321: Photo Gallery
322: Forums
323: Forums
324: Forums
325: Home
326: Photo Gallery
327: Forums
328: Forums
329: Forums
330: Forums
331: Forums
332: Forums
333: Forums
Forums › Marker Talk › Problem/Tech forum :: Archives › Bushmater cycles but doesn't fire :: Archived
Go to page 1, 2, 3, 4, 5, 6  Next
L3G0
PostPosted: Sun Jul 17, 2011 10:34 pm    Post subject: Bushmater cycles but doesn't fire
Okay, I read 2 other threads of this calibre and my valve is not upside down, nor is my bolt. Okay so.. the gun gasses up fine. bolt goes back. but when I fire the gun, the bolt only seems to travel quarter or sometimes half of the way of the travel it should. My high pressure reg shows 400PSI and i've reset my LPR multiple times by turning in until it leaks then backing it off 2 turns, I dont' see very much drop on my gauge during cycle.. and it seems like it has full power to everywhere.. but no air comes from the barrel. Im completely stumped! what should i try?
Thanks, Dan
I verified that the ram rod/bolt is not travelling far enough to hit the pin to allow the air to flow and fire the ball.
PostPosted: Sun Jul 17, 2011 10:49 pm    Post subject: Re: Bushmater cycles but doesn't fire
Dan,
First, lower the pressure on your guage to about 200-225 psi. 400 is way too much. Second, turn your lpr in until the solenoid vents and then back out about one half turn. That should get things cycling. If you aren't shooting at those pressures, then we need to know what kind of board you have to see if maybe the dwell is low. Other than that, you need to make sure your ram/bolt assembly moves smoothly. If your bolt sticks anywhere along the travel, that can cause cycling problems.
See what that does and get back with us.
-Colin
L3G0
PostPosted: Sun Jul 17, 2011 11:10 pm    Post subject: Re: Bushmater cycles but doesn't fire
thank you for the reply,
Okay, I did as you said.. I lowered it to 225psi at the HPR guage, turned out the LPR again, the gun is continuing to cycle the same.. only pushes the ram rod/bolt forward quarter to half the actual travel at full speed, repeatedly. I checked my ram rod and bolt movement again... seems fine no sticks tight spots, i even relubed the ram rod a bit.
seems like it doesn't have enough force to push the ram rod forward to hit the pin. If i give it a little tug forward while cycling it (I know.. bad idea) it will cycle but only while tugging a bit during cycling..
Its an un modified BUshmaster B 2 K w/ PDS, Ninja 68/4500 UL (450ish psi).
its automatically turning b 2 k into bushmaster when i submit :/
PostPosted: Sun Jul 17, 2011 11:33 pm    Post subject: Re: Bushmater cycles but doesn't fire
Take the tray off, and see if your solenoid, or solenoid manifold has become obstructed; either with a piece of o-ring or teflon tape or something.
Also, you solenoid gasket might be crushed from over-tightening your noid onto the manifold.
What kind of ASA are you using?
PostPosted: Sun Jul 17, 2011 11:37 pm    Post subject: Re: Bushmater cycles but doesn't fire
Sorry, that's one of my OCD auto correct things.
Have you had this Bushy very long? Have you cleaned and lubed the ram? If you bought it used, it may very well have an aftermarket board in it. At those pressures and with the correct dwell and a lubed ram, there should be no problems. Give us some history and we'll figure it out.
L3G0
PostPosted: Sun Jul 17, 2011 11:44 pm    Post subject: Re: Bushmater cycles but doesn't fire
I will check the solenoid for an obstruction. well I did tighten 1 solenoid screw, and your going to love this story. It will also be the history.
I bought this bushy brand new! in '02 or '03. Guns shows up! SO DOES A BABY XD. Needless to say, the setup was never finished and i haven't had the cash to finish my rig or play up until now. So i ordered my tank/hopper etc. went the first day. Gave the gun a once over for lube/seals, just checking everything. Gun shot beautiful. home, clean, back to box... second time we go.. somehow my hpr vertical asa comes loose and my gun basically fell apart in my hands. used a rental that day.... put the gun back together dry fire it a few times. works great again. went to go to the field today. and it fires but doesnt' shoot paint Sad
EDIT
Oh yea that screw.. since the day i bought the gun it had a rattle in it.. when i dismanteled the gun to fix the vertical asa i found the back right solenoid screw rolling around :/
EDIT AGAIN...
my bottomline ASA is a CP /on off i believe i forget what brand but it works great no problems with it or my macro line.. i opened it up with the macro disconnected to see if i was getting tons of air and i am XD
PostPosted: Mon Jul 18, 2011 12:02 am    Post subject: Re: Bushmater cycles but doesn't fire
Not the dwell then. Sounds just like some ram stick. Or a noid issue.
Is the battery fresh? I bet its the battery.
L3G0
PostPosted: Mon Jul 18, 2011 12:08 am    Post subject: Re: Bushmater cycles but doesn't fire
Brand new battery Razz
ANYWAY, we have some head way Smile I took the 'noid' off. looked very clean not to much lube BUT the little clear oring was well oddly shapped.. so i reformed it, put the noid back on gassed up the gun, reset lpr, and i had blowback XD but my noid is leaking all over the place so i have to see if i can tighten it just a touch more without mucking it up again.. but i be you will recommend a set of new orings wont ya Smile
PostPosted: Mon Jul 18, 2011 12:33 am    Post subject: Re: Bushmater cycles but doesn't fire
check the noid again, as it sounds like you could have put the noid piston in backwards. there should be only a light sheen to the orings, nothing more. except for the valve screw, all the screws should only be tightened to finger tight. the screws don't need to be torqued down.
next, since the gun was new from 02/03, i'm thinking that there is possibly a bad oring in the ram, or lack of lube on the ram itself. this would have caused the slow shot.
also, check the ball detent i it has a cocker detent. too far, and the bolt will bounce off it and not cycle properly.
also, check to make sure that the bolt pin is sitting properly in the ram. the gun could be cycling properly, but if the bolt pin is not seated correctly, it would make the bolt not move, but shoot correctly.
L3G0
PostPosted: Mon Jul 18, 2011 1:04 am    Post subject: Re: Bushmater cycles but doesn't fire
nah the dents are fine, same as the rod and stuff i've check it many times.. you had it right with the noid...
There is 3 things on it when i take it off.. a big oval black oring, at the back, with the clear oring in the middle, which i said it is deformed, and now see its has 2 cracks, and one more small black oring at the front. I just changed the clear one. as i had one.... now i have the lpr basically screwed out all the way, and no matter how tight or loose i put the noid screws it leaks, but when it gets close to sealing it cycles with blow back..
basically I think i just need to get it to seat and seal. correct?
Page 1 of 6
How do you hit pictures in NBA2K21?
Last post by wfuuopy in Off Topic on Nov 20, 2020 at 01:53:02
RuneScape is Free-To-Play
Last post by wfuuopy in Paintball talk on Nov 20, 2020 at 01:52:09
If You Are Clever About It
Last post by Kingang in Off Topic on Nov 18, 2020 at 10:05:37
Their Previous Narrative Manners
Last post by Kingang in Off Topic on Nov 18, 2020 at 10:04:15
You'Ll Take A Massive Loss On The Maples
Last post by Kingang in Off Topic on Nov 18, 2020 at 10:02:01
Last post by Tzarector in ICD Gear Forum on Nov 05, 2020 at 17:20:50
adidas online kopen
Last post by YAz45mmi in Calendar of Events on Oct 24, 2020 at 04:06:09
NikeLab Dunk Lux SP Dark
Last post by YAz45mmi in Off Topic on Oct 24, 2020 at 03:59:37
Converse har spillet med
Last post by YAz45mmi in Paintball talk on Oct 24, 2020 at 03:51:39
adidas EQT-Kissen ADV
Last post by YAz45mmi in PRP General Forum on Oct 24, 2020 at 03:45:37
