Latest: Osweiler
New Yesterday: 1
Overall: 7925
Visitors: 173
Total: 173
87: Home
94: Home
111: Home
125: Home
128: Home
130: Home
136: Your Account
163: Photo Gallery
166: Home
Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Mon Jul 18, 2011 1:32 am    Post subject: Re: Bushmater cycles but doesn't fire
Hey, welcome to ICDO. Help yourself to drinks in the 'fridge.
L3G0
PostPosted: Mon Jul 18, 2011 3:22 pm    Post subject: Re: Bushmater cycles but doesn't fire
okay i can't seem to get my manifold to seal properly.. i replaced the clearish oring in the middle and i've tried various tightnesses of the screws near finger tight. If i go slightly tight i get a seal but the gun doesn't cycle. and if i let a touch loose, it leaks all over the place but i can get the odd proper cycle :/ is it possible i have to replace all three (the clear oring and the 2 black orings/seals) ?
L3G0
PostPosted: Mon Jul 18, 2011 3:52 pm    Post subject: Re: Bushmater cycles but doesn't fire
okay i have the solenoid screws set that it will cycle .. kinda i get a few shots.. but its still leaking.
I think i messed up the HPR orings.. because now im getting a puff of air out of the adjustment screw.
Im thinking of just taking it to the local shop and asking them to replace the oring/seals and the HPR orings. Sad
Im getting very frustrated with this gun since its basically brand new and used twice Sad well fell apart the second use Sad
L3G0
PostPosted: Mon Jul 18, 2011 8:38 pm    Post subject: Re: Bushmater cycles but doesn't fire
can i even get orings/gaskets to fit this gun still?
PostPosted: Tue Jul 19, 2011 3:14 am    Post subject: Re: Bushmater cycles but doesn't fire
yes, ICD still sells new oring kits that are complete. gaskets are harder as the only place i know of is Airsoldier but they are sold out.
L3G0
PostPosted: Tue Jul 19, 2011 10:32 am    Post subject: Re: Bushmater cycles but doesn't fire
whats this gasket you keep speaking of.. i dont' have one.. (like similar to a manifold gasket on a car?) .... All I've got is the little clear oring.. and the medium sized black oringish thing and the large black oring.
should i take a pic of it and show you what i mean?
L3G0
PostPosted: Tue Jul 19, 2011 10:34 am    Post subject: Re: Bushmater cycles but doesn't fire
im on a roll.. now i snapped the solder to one of my eyes Sad
is there a link to the kit?
PostPosted: Tue Jul 19, 2011 12:29 pm    Post subject: Re: Bushmater cycles but doesn't fire
the gasket meets the noid to the manifold. pics of the gun, and your problems would help greatly.
PostPosted: Tue Jul 19, 2011 1:27 pm    Post subject: Re: Bushmater cycles but doesn't fire
^This
L3G0
PostPosted: Tue Jul 19, 2011 1:41 pm    Post subject: Re: Bushmater cycles but doesn't fire
GUN: imageshack.us/photo/my...447nc.jpg/ [/IMG]
SOLENOID ATTACHED: imageshack.us/photo/my...1448c.jpg/
SOLENOID BOTTOM: imageshack.us/photo/my...451yd.jpg/
OKAY NOW IM REALLY MESSED UP.... I took my hpr apart to check the orings... and now i have a little brass circle with a nipple, a ball bearing, and a spring... What order do they go... i checked the schematics page.. but none of them match mine OMFG what else can go wrong. is there a schem of my reg?
ADDING... K little brass circle faces up the little hole, then the ball bearing then the spring then the plunger right? well the plunger has to go last. it has the long pin that pushs into the other part of the reg.
Page 2 of 6
Mike Tomlin implies there is a trong possibilitythe Steelers
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:45:00
Packers stay on offense, add RB A.J. Dillon
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:44:39
For 2nd straight season, Seahawks offense struggling to fly
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:44:12
Chiefs welcome fresh/outdated faces inside of Allen
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:43:58
Run defense issues highlight total breakdown for Saints
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:43:15
Pitch and catch: Round 2 of NFL draft heavy on receivers
Last post by Osweiler in Off Topic on Nov 26, 2020 at 03:42:37
Corridor of Fame QB Jim Kelly suggests checks demonstrate re
Last post by Osweiler in Paintball talk on Nov 26, 2020 at 03:42:15
How do you hit pictures in NBA2K21?
Last post by wfuuopy in Off Topic on Nov 20, 2020 at 01:53:02
RuneScape is Free-To-Play
Last post by wfuuopy in Paintball talk on Nov 20, 2020 at 01:52:09
If You Are Clever About It
Last post by Kingang in Off Topic on Nov 18, 2020 at 10:05:37
