Latest: wfuuopy
Overall: 7924
Visitors: 241
Total: 241
01: Home
54: Home
124: Home
150: Home
166: Photo Gallery
172: Home
181: Home
192: Photo Gallery
197: Photo Gallery
205: Photo Gallery
211: Photo Gallery
225: Photo Gallery
233: Photo Gallery
235: Home
Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Tue Jul 19, 2011 2:55 pm    Post subject: Re: Bushmater cycles but doesn't fire
i do believe that the reg is like the other stock reg, the Freestyle and Promaster ones, just the appearance has changed.
would like a pic of the harness so we could see the damage. but don't worry, you aren't the first, nor the last to have a damaged harness. ICD stock harnesses have very thin wires. now, if you would like, send the harness to me, i'll change out the wires, reattach the parts and send it back to you. look here for my Super Saver Furious Harness.
L3G0
PostPosted: Tue Jul 19, 2011 3:08 pm    Post subject: Re: Bushmater cycles but doesn't fire
Im honestly not that worried about the eye wire. I can repair that, the wire just came diconnected from the switch. Im concerned about my solenoid, and why i can't get it to seal and cycle thats why the pics are of it. I'll take a look at the schematic for those regs and get it put back together also.
Were are the schematics? i was looking at a wrong one on a different site.
pretty sure i have the HPR put back together right anyway.
PostPosted: Tue Jul 19, 2011 3:23 pm    Post subject: Re: Bushmater cycles but doesn't fire
HPR breakdown
everything is in the Bushmaster FAQ.
L3G0
PostPosted: Tue Jul 19, 2011 3:48 pm    Post subject: Re: Bushmater cycles but doesn't fire
okay i see what you mean about the gasket now... i checked it, no damage. the seals are fine. and i put the hpr back together...
thats the wrong hpr
EDIT GOT THE RIGHT ONE...
L3G0
PostPosted: Tue Jul 19, 2011 3:55 pm    Post subject: Re: Bushmater cycles but doesn't fire
fivestring wrote:
ICD Stock High Pressure Regulator Breakdown
HPR
**Please note the the Reg seal in both pictures is not shown. The reg seal is a soft rubber disc that seals against the brass piston.**
the little brass thing isn't show or am i blind Razz um so i would assume it faces up? when it fell out it was between the top and the ball bearing, has to have been.
anyway back the the manifold/solenoid.. what should i do.. the gasket is fine.. the 3 orings on the manifold look fine.
PostPosted: Tue Jul 19, 2011 6:47 pm    Post subject: Re: Bushmater cycles but doesn't fire
Do you have any different hprs? It could be jacked, and not be letting air though. All of my stock hprs gave me trouble.
L3G0
PostPosted: Tue Jul 19, 2011 7:26 pm    Post subject: Re: Bushmater cycles but doesn't fire
no i don't but i guess i could order one... is there a good cheap reg i could buy that wouldnt' put to big of a dent in my pocket but still be pretty good. and would the reg really affect the solenoid ? i thought the lpr would do that?
PostPosted: Tue Jul 19, 2011 7:50 pm    Post subject: Re: Bushmater cycles but doesn't fire
I mean, it wouldn't directly, but if it is faulty, it could be causing problems (no air getting to the noid and lpr, therefore, no cycling)
Pm me your address, and I will send you a cheapo hpr and lpr to try out, see if that fixes any of your problems.
L3G0
PostPosted: Tue Jul 19, 2011 8:27 pm    Post subject: Re: Bushmater cycles but doesn't fire
Thanks, I PM'd you. I have to head to the shop tonight and get my tanks filled so i can try again, now that i have everything back together.
L3G0
PostPosted: Wed Jul 20, 2011 12:45 pm    Post subject: Re: Bushmater cycles but doesn't fire
Okay so, I guess this is an important question... you guys have been saying the solenoid is like finger tight correct? But, I was under the impression that you guys were talking about the solenoid manifold to the body needs to be finger tight. because i never really realized that the solenoid and the manifold were 2 different parts and the gasket was between them (I know, duh, moron, you work on cars and know the difference between a gasket and a manifold and an oring...).
SO, Im supposed to tighten the manifold to the body pretty tight and the solenoid to the manifold finger tight. Correct?
Page 3 of 6
How do you hit pictures in NBA2K21?
Last post by wfuuopy in Off Topic on Nov 20, 2020 at 01:53:02
RuneScape is Free-To-Play
Last post by wfuuopy in Paintball talk on Nov 20, 2020 at 01:52:09
If You Are Clever About It
Last post by Kingang in Off Topic on Nov 18, 2020 at 10:05:37
Their Previous Narrative Manners
Last post by Kingang in Off Topic on Nov 18, 2020 at 10:04:15
You'Ll Take A Massive Loss On The Maples
Last post by Kingang in Off Topic on Nov 18, 2020 at 10:02:01
Last post by Tzarector in ICD Gear Forum on Nov 05, 2020 at 17:20:50
adidas online kopen
Last post by YAz45mmi in Calendar of Events on Oct 24, 2020 at 04:06:09
NikeLab Dunk Lux SP Dark
Last post by YAz45mmi in Off Topic on Oct 24, 2020 at 03:59:37
Converse har spillet med
Last post by YAz45mmi in Paintball talk on Oct 24, 2020 at 03:51:39
adidas EQT-Kissen ADV
Last post by YAz45mmi in PRP General Forum on Oct 24, 2020 at 03:45:37
