Menu: |
User Info |
Donations |
Donate and suport ICDO! |
Forums › Marker Talk › Problem/Tech forum :: Archives › empire valve users :: Archived |
empire valve users Have a problem with your marker? Ask here
Author |
Message |
pump I like bukkake!
Back to top |
MuthaFunk ICDO Supporter
Joined: Nov 14, 2006 Posts: 815 Location: Burlington, Ontario, Canada
Posted: Sun Aug 28, 2011 3:49 pm Post subject: Re: empire valve users |
When I had mine I think I had to use a lighter one to get the proper FPS out it.
_________________ Always looking for better..... |
Back to top |
Back to top |
Posted: Tue Nov 08, 2011 12:52 am Post subject: Re: empire valve users |
I'm going off of memory for quite a while but I think I ended up with a stock dwell.... 10mS? or 12 mS.
LPR setting whas around 55 psi..... I can't really remember. Sorry. I'll go back and check my threads to see if I posted it anywhere...
Back to top |
Posted: Tue Nov 08, 2011 1:04 am Post subject: Re: empire valve users |
Here's the quote from my thread. I was using a ACP lightened hammer and a lighter spring. I remember I had kept going lighter and lighter until the oring wouldn't seal. I can't remember what spring I ended up on. You might be able to find out somewhere in the thread I made linked below the quote.
Quote:: |
When you're running your marker on the hairy edge, a bolt with orings has too much friction. That being said I'm still running 80 PSI on the LPR with a dwell of 12 ms but the HP is at 210 for around 280 FPS. I know, strange #'s but the hammer is very light and the Empire valve doesn't seem to compensate for higher HP pressures as much as I expected. I thought with the AA function of the valve I wouldn't need nearly as much force to open the valve but In practice now I see it only helps a little bit. |
MuthaFunk Bushy Project Thread
Back to top |
fungunzbuff PL B2K Scrooge
Posted: Tue Nov 08, 2011 2:08 am Post subject: Re: empire valve users |
Mine has a MUCH lighter spring. Dwell is at 9. Don't remember pressures off the top of my head.
_________________ Thunderstruck.
maloneoni wrote: |
They look good. |
Back to top |
Back to top |
Posted: Tue Nov 08, 2011 11:42 am Post subject: Re: empire valve users |
Yeah, the friction is a killer.
I work at a dentist hand piece repair facility, and they have tons of polishing equipment. I have just been polishing like crazy lately. I'll try a polish on the valve stem, and valve and see if that helps.
maloneoni wrote: |
They look good. |
Back to top |
Posted: Tue Nov 08, 2011 3:44 pm Post subject: Re: empire valve users |
I remember I had to shorten the valve stem on mine to match a stock valve as the original length of the Empire valve stem was much longer and caused alignment issues with the valve opening before the bolt intake hole was fully exposed to the air supply through the body.
I don't know if they were all like that or if it was simply a question of quality control.
Back to top |
Back to top |
Photo Gallery Pics... |
Forums scroll Last posts |
Last 10 Forum Messages |
