Latest: NisaDisco
Overall: 7919
Visitors: 138
Total: 138
58: Your Account
79: Home
97: Home
110: Home
117: Home
118: Home
123: Home
Forums › General › Paintball talk :: Archives › Realy po'd with icd... :: Archived
Go to page Previous  1, 2, 3, 4, 5  Next
Headshotted
PostPosted: Thu Oct 13, 2011 8:57 pm    Post subject: Re: Realy po'd with icd...
That's odd. Your detonator should be able to push way more than that, considering it was on a Pimp, and Pimps are just faster than god impulses. That might be problem number one right there. Also, I find I have better luck balancing with a squeegee. I'll tell you what, I'll post a video of how to do it saturday or sunday hopefully once my gear gets here.
PostPosted: Thu Oct 13, 2011 8:58 pm    Post subject: Re: Realy po'd with icd...
Eh, omen... but they were on pimps to.
Video sounds great, thanks.
PostPosted: Thu Oct 13, 2011 8:59 pm    Post subject: Re: Realy po'd with icd...
When they go above 200 psi, what happens? Do you have another gauge you could try?
PostPosted: Thu Oct 13, 2011 9:01 pm    Post subject: Re: Realy po'd with icd...
Just getting ready to say that.
There is no way both are pooping out at 200. Sounds like your gage is either messed up, or too low a pressure gauge.
PostPosted: Thu Oct 13, 2011 9:02 pm    Post subject: Re: Realy po'd with icd...
All right... heres what happens.
When i get to about 190, there is a light hissing in the grip frame...
when pushed to 200, it sounds like its cycling, then pops. If you watch the video again, you'll hear it.
The needle on the reg rises, then drops, rises, then drops.
If you go to 250 psi, it spews air out of the frame. It starts trying to cycle faster, but fails to.
Happens on both regs exactly as described.
PostPosted: Thu Oct 13, 2011 9:03 pm    Post subject: Re: Realy po'd with icd...
That is super weird. SOunds like your lpr is set WAY to high.
PostPosted: Thu Oct 13, 2011 9:06 pm    Post subject: Re: Realy po'd with icd...
^ That is with it backed out %100.
PostPosted: Thu Oct 13, 2011 9:09 pm    Post subject: Re: Realy po'd with icd...
Are you sure that you have not turned it all the way up instead of turning it all the way off?
PostPosted: Thu Oct 13, 2011 9:10 pm    Post subject: Re: Realy po'd with icd...
www.youtube.com/watch?v=9zDvkR5fpU8
Ive tried both ways! it does the same thing.
PostPosted: Thu Oct 13, 2011 9:13 pm    Post subject: Re: Realy po'd with icd...
If your reg is oscillating like that, then something is wrong with your reg.
Turn your HPR up to like 150 then, and then slowly turn you lpr up until the bolt goes back, and then a little more, for starters.
Is your bolt all the way forward, or back with your lpr all the way at 0?
Page 4 of 5
Nike Air Max 90 zu seiner
asics scarpe basso prezzo
basket adidas femme pas cher
nike air max 2090 hombre
