Visitors: 301
Total: 301
47: Your Account
126: Home
134: Home
136: Home
156: Home
157: Photo Gallery
165: Home
168: Photo Gallery
173: Home
182: Home
183: Home
189: Photo Gallery
193: Photo Gallery
209: Photo Gallery
229: Photo Gallery
230: Photo Gallery
236: Photo Gallery
237: Photo Gallery
238: Photo Gallery
241: Photo Gallery
244: Photo Gallery
247: Photo Gallery
248: Photo Gallery
249: Photo Gallery
252: Photo Gallery
253: Home
256: Photo Gallery
257: Photo Gallery
258: Photo Gallery
259: Photo Gallery
260: Photo Gallery
261: Home
262: Forums
263: Forums
264: Home
265: Photo Gallery
266: Photo Gallery
267: Forums
268: Photo Gallery
269: Photo Gallery
271: Photo Gallery
272: Forums
273: Photo Gallery
274: Forums
275: Forums
277: Forums
278: Photo Gallery
279: Photo Gallery
280: Photo Gallery
281: Forums
282: Home
283: Forums
285: Forums
286: Forums
287: Forums
288: Forums
289: Forums
290: Forums
291: Photo Gallery
292: Forums
293: Photo Gallery
294: Forums
295: Forums
296: Forums
297: Forums
298: Forums
299: Forums
300: Forums
301: Photo Gallery
Forums › Marker Talk › Problem/Tech forum :: Archives › empire valve users :: Archived
empire valve users
pump
I like bukkake!
I like bukkake!
PostPosted: Sat Aug 27, 2011 3:26 pm    Post subject: empire valve users
how many use stock springs?
if you do how has performance changed?
autotriggers for sale
Shocktech B2Ks
NIB Warp Feeds FS
MuthaFunk
PostPosted: Sun Aug 28, 2011 3:49 pm    Post subject: Re: empire valve users
When I had mine I think I had to use a lighter one to get the proper FPS out it.
pump
I like bukkake!
I like bukkake!
PostPosted: Sun Aug 28, 2011 4:05 pm    Post subject: Re: empire valve users
ah good info, what was the dwell and psi after you installed it?
Shocktech B2Ks
NIB Warp Feeds FS
MuthaFunk
PostPosted: Tue Nov 08, 2011 12:52 am    Post subject: Re: empire valve users
I'm going off of memory for quite a while but I think I ended up with a stock dwell.... 10mS? or 12 mS.
LPR setting whas around 55 psi..... I can't really remember. Sorry. I'll go back and check my threads to see if I posted it anywhere...
MuthaFunk
PostPosted: Tue Nov 08, 2011 1:04 am    Post subject: Re: empire valve users
Here's the quote from my thread. I was using a ACP lightened hammer and a lighter spring. I remember I had kept going lighter and lighter until the oring wouldn't seal. I can't remember what spring I ended up on. You might be able to find out somewhere in the thread I made linked below the quote.
Quote::
When you're running your marker on the hairy edge, a bolt with orings has too much friction. That being said I'm still running 80 PSI on the LPR with a dwell of 12 ms but the HP is at 210 for around 280 FPS. I know, strange #'s but the hammer is very light and the Empire valve doesn't seem to compensate for higher HP pressures as much as I expected. I thought with the AA function of the valve I wouldn't need nearly as much force to open the valve but In practice now I see it only helps a little bit.
MuthaFunk Bushy Project Thread
PostPosted: Tue Nov 08, 2011 2:08 am    Post subject: Re: empire valve users
Mine has a MUCH lighter spring. Dwell is at 9. Don't remember pressures off the top of my head.
pump
I like bukkake!
I like bukkake!
PostPosted: Tue Nov 08, 2011 4:10 am    Post subject: Re: empire valve users
yeah i really need to try a stock board and noid
but it seems that the valve opens easier but friction and whatever else makes for so so performance
Shocktech B2Ks
NIB Warp Feeds FS
PostPosted: Tue Nov 08, 2011 11:42 am    Post subject: Re: empire valve users
Yeah, the friction is a killer.
I work at a dentist hand piece repair facility, and they have tons of polishing equipment. I have just been polishing like crazy lately. I'll try a polish on the valve stem, and valve and see if that helps.
MuthaFunk
PostPosted: Tue Nov 08, 2011 3:44 pm    Post subject: Re: empire valve users
I remember I had to shorten the valve stem on mine to match a stock valve as the original length of the Empire valve stem was much longer and caused alignment issues with the valve opening before the bolt intake hole was fully exposed to the air supply through the body.
I don't know if they were all like that or if it was simply a question of quality control.
pump
I like bukkake!
I like bukkake!
PostPosted: Tue Nov 08, 2011 9:09 pm    Post subject: Re: empire valve users
Yeah I discovered that lol
I think it was intentional
I'll ask simon
Oh and polishing does help only the tip that slides inside the oring
But I have u cup rings that I put in the middle o ring position and it helps a lot
I want one for the tip as well
Shocktech B2Ks
NIB Warp Feeds FS
