Latest: phalupasuan
Overall: 7907
Visitors: 86
Total: 86
Forums › Marker Talk › Problem/Tech forum :: Archives › damn bushy, more problems!!!!~any help?? :: Archived
bushyguy721
PostPosted: Sun Mar 28, 2004 7:02 pm    Post subject: damn bushy, more problems!!!!~any help??
ok i was gunna sell ym gun today locally......BUT my bushy was leakin and when i shot the led light didnt blink
i dont care about the light cus well who cares, but the damn leak bothers me sooo much and he wouldnt buy it until i fixed it...i leaks somewhere inside around where the noid is i think its that but i dunno...after doin some taken apart i think its either the lpr or the valve
if it is that how do i fix it, buy a new noid?
i need some help please, if i need to take it apart any pics would be apprecaited
misterj0shua
PostPosted: Sun Mar 28, 2004 8:29 pm    Post subject: Some Ideas
I just got through a bunch of crap with the bushy (im also haveing the same problem believe it or not) I have and here are a few ideas that may or may not help ya.
I can tell ya its not the valve. You said it was leaking around the noid. If it was the valve you would have all sorts of leakage around the gun...down the barrell...etc. everything in that noid is regualted internally though little tunnels and holes on the gun. But the noid I noticed through the last several months will bleed (or leak) off in two ways. Either A. The pressure is too high or B. 1 of the o-rings on the noid is bad. you then ask ok how do i know which one. What i do is take apart my gun and gas it up. Where the noid attaches to the frame if the air leakes out of their then it is a oring or the noid is attached tight enough. 2. between the base of the noid and the noid itself...the only thing i can figure is this is where it bleeds off excess pressure.
now if it 2 then you got two problems. Either A. Your LPR is not working correctly (or is too far in) or B. The noid is bad. This is where i am stuck now. The most im going to do is replace the orings on the piston in the LPR and if that dont work...im going to have to buy a new noid.
The question I have is (which im sure is a yes). Does the piston on the lpr move every shot...or does it saty where it is. Cause if that is the problem...that would explain my issues.
oh btw.....the noid needs a certain number of volts to function so you may want to look at a battery issue too. Also check out the wiring harness and may sure there are no disconnections...just a though
Laughing
Barber
Hope this helped...
misterj0shua
PostPosted: Sun Mar 28, 2004 8:52 pm    Post subject: BTW I found this...
I found this while searching for the problem....I guess we are having it should help. This should tell ya whether you need a new noid.
www.icd-owners.com/htm...pic&t=1187
Big_Mac
PostPosted: Mon Mar 29, 2004 9:15 am    Post subject:
Didn't read the referenced post...hope I'm not repeating.
Yes, check the LPR...too high will cause the noid to bleed off. Check the screw holding the noid to the ram to make sure they are tight.
that's all I can think of right now. Smile
Stupidity Kills
misterj0shua
PostPosted: Mon Mar 29, 2004 9:50 pm    Post subject: Fixed problem....
Just an update...i replaced the piston o-rings and adjusted the pressure between the HPR and the LPR and it works great...
bushyguy721
PostPosted: Thu Apr 08, 2004 11:03 am    Post subject:
sry i havnt replied to the thread lately, i am goin to the field today and everyone knows bushys there so we all will fix it, hopefully i wont have to get a new noid, if i do then crap.....THANKS for all you guy's help its been greatly appriecaited
Last post by Walkertl in ICD Mech Markers on Apr 24, 2018 at 01:01:57
Last post by ViperXT in ICD Gear Forum on Apr 18, 2018 at 13:51:13
Looking for kila drive or NOX board.
Last post by ViperXT in ICD Gear Forum on Apr 14, 2018 at 12:43:16
Last post by Tzarector in ICD Gear Forum on Mar 30, 2018 at 04:05:35
Last post by Un2XS in PRP General Forum on Mar 25, 2018 at 21:32:43
WTB: Promaster
Last post by ViperXT in ICD Gear Forum on Mar 23, 2018 at 16:16:25
Last post by moodydoody in Paintball talk on Mar 22, 2018 at 07:10:48
