Visitors: 69
Total: 69
01: Home
40: Your Account
Forums › General › Paintball talk :: Archives › What do i do with my 05 Ego Frame and Noid? :: Archived
Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Dec 09, 2011 12:24 pm    Post subject: Re: What do i do with my 05 Ego Frame and Noid?
a shooter when lining up a shot is only going to raise his gun to eye level. about level with the top tube regardless of the positioning of the frame and height of the tray. so the height below the top tube/barrel is essentially irrelevent. the height above the top tube is FAR more important especially when shooting from behind cover as your loader will be exposed sooner with a tall feedneck compared to a low/no rise neck.
also based on weight comparisons done by F G B a while back the Eclipse is the lightest of the PL bushies IIRC, but that is not the point I am making.
i think i made a mistake on my previous post though. The T2 uses a separate manifold and the T1 used an iintigrated manifold. been a while since i handled one. my mistake.
BIP8ntball
PostPosted: Fri Dec 09, 2011 12:58 pm    Post subject: Re: What do i do with my 05 Ego Frame and Noid?
Arent the qevs designed to be cleaned and reassembled/orings replaced?
AIM: PBKING51
EMAIL:PBking51@aol.com
PostPosted: Fri Dec 09, 2011 1:18 pm    Post subject: Re: What do i do with my 05 Ego Frame and Noid?
some are, some aren't. some can be unscrewed to replace the diaphrams. usually have loctite on them and you end up jacking up the housing separating them. i would try it though.
pump
I like bukkake!
I like bukkake!
PostPosted: Fri Dec 09, 2011 5:49 pm    Post subject: Re: What do i do with my 05 Ego Frame and Noid?
The t1 or 2 is very clumbersom with a stock harness, but the icd harness sucks balls, I use a Mac dev board and omg so nice no hassle at all
A trayless bushmaster feels a while lot better than a trayed because the weight is closer to your hand and the angle is nice feels good to me
While I think newer frames feel better that's because they don't need to run a noid in that config with it being positioned before hand not after
But a vert noid manifold would make this interesting
autotriggers for sale
Shocktech B2Ks
NIB Warp Feeds FS
Rudz
PostPosted: Fri Dec 09, 2011 7:17 pm    Post subject: Re: What do i do with my 05 Ego Frame and Noid?
You mean like the Promaster framed Bushys? Smile
ADDIX Paintball
Action Star Games
Almost Famous Photography
BIGEVILONLINE.COM
pump
I like bukkake!
I like bukkake!
PostPosted: Fri Dec 09, 2011 9:27 pm    Post subject: Re: What do i do with my 05 Ego Frame and Noid?
thats hosed though, a manifold would be nice for b2ks
Shocktech B2Ks
NIB Warp Feeds FS
PostPosted: Fri Dec 09, 2011 10:06 pm    Post subject: Re: What do i do with my 05 Ego Frame and Noid?
so basically, you want a noid manifold but with the hump frame? that's a T2, if i'm not mistaken.
actually, what i would like to see is a non-hosed, non manifold Bushmaster.
hmmm, i have been thinking about putting a Ego, or a Cyborg ram in a Bushmaster, only because of the higher availability of parts, but aftermarket. from PE, getting a zick2 or 3. i think that would be awesome.
i need to find a set of numbers for the internal measurements.
pump
I like bukkake!
I like bukkake!
PostPosted: Fri Dec 09, 2011 10:33 pm    Post subject: Re: What do i do with my 05 Ego Frame and Noid?
no i was wanting a vert manifold when did i say hump? yuck!
why no manifold? the threads and the milling is so fine with solenoids if you mess that up, like one shoebox shockers, then whole gun is worthless, but a manifold can be replaces
the cyborg started out as a Bushmaster upgrade
it cant be that hard to just mod a stock ram to take a cyborg rammer
Shocktech B2Ks
NIB Warp Feeds FS
PostPosted: Fri Dec 09, 2011 11:26 pm    Post subject: Re: What do i do with my 05 Ego Frame and Noid?
the modded Bushmaster ram was another thought. much easier, as you can take a stock ram housing, and add in a sleeve to take up the room for the new ram shaft. but was thinking more about a PE ram, since people can't give away the old stock/upgraded unwanted rams.
good point about the manifold. never thought about it that way.
thought the frame was a hump, and not the vert manifold.
pump
I like bukkake!
I like bukkake!
PostPosted: Fri Dec 09, 2011 11:35 pm    Post subject: Re: What do i do with my 05 Ego Frame and Noid?
Don't think an ego rammer would fit but a cyborg might
But nothing really wrong with a polished modded stock ram imo
Shocktech B2Ks
NIB Warp Feeds FS
Page 3 of 4
