Latest: igo5apzv
New Today: 1
Overall: 7921
Visitors: 338
Total: 338
67: Home
108: Home
113: Home
122: Home
132: Home
165: Photo Gallery
167: Photo Gallery
174: Photo Gallery
184: Photo Gallery
189: Photo Gallery
200: Photo Gallery
205: Photo Gallery
207: Photo Gallery
208: Home
219: Photo Gallery
226: Photo Gallery
231: Home
235: Photo Gallery
244: Photo Gallery
247: Photo Gallery
251: Photo Gallery
252: Photo Gallery
254: Photo Gallery
256: Photo Gallery
258: Home
262: Your Account
263: Forums
266: Home
267: Forums
270: Photo Gallery
271: Forums
272: Photo Gallery
273: Home
274: Home
275: Forums
277: Photo Gallery
279: Photo Gallery
280: Photo Gallery
281: Photo Gallery
283: Forums
285: Forums
286: Forums
287: Photo Gallery
288: Forums
289: Photo Gallery
290: Forums
291: Forums
292: Photo Gallery
293: Forums
294: Forums
295: Photo Gallery
296: Photo Gallery
297: Photo Gallery
298: Your Account
299: Photo Gallery
300: Photo Gallery
301: Forums
302: Forums
303: Forums
304: Photo Gallery
305: Forums
306: Forums
307: Forums
308: Forums
309: Photo Gallery
310: Forums
311: Photo Gallery
312: Forums
313: Photo Gallery
314: Forums
315: Forums
316: Photo Gallery
317: Forums
318: Forums
319: Photo Gallery
320: Forums
321: Photo Gallery
322: Photo Gallery
323: Forums
324: Forums
325: Photo Gallery
326: Forums
327: Photo Gallery
328: Forums
329: Forums
330: Forums
331: Photo Gallery
332: Photo Gallery
333: Forums
334: Forums
335: Forums
336: Forums
337: Forums
338: Forums
Forums › General › Paintball talk › Official Non-ICD marker discussion thread
Go to page Previous  1, 2, 3, ... 65, 66, 67  Next
butternutvalley
PostPosted: Fri Dec 23, 2011 2:37 pm    Post subject: Re: Official Non-ICD marker discussion thread
Came with the proficiency engine extra and wanted to give a quick lube before installing, but unable to get the pillow bolt removed from the ram shaft.
Used quite abit of force, but worried about bending/breaking.
Any help/idea?
ICDO Feedback - www.icd-owners.com/htm...ic&t=14665
I do as I please as long as it's been approved by the wife........or she doesn't know about it yet
butternutvalley
PostPosted: Fri Dec 23, 2011 3:16 pm    Post subject: Re: Official Non-ICD marker discussion thread
Just put some paint through it. Set lpr/hpr with pressure tester at:
lpr=70
hpr=210
Shot over chrono and had to raise hpr to get 270fsp.
Checked with pressure tester after and hpr is 250psi now. Is this normal operating pressure?
loud & pingy.
Also couldn't get my rotors to go on, feednecks must be to big. Had to use primo hopper!
Trigger needs major tune up. Double&triple shots in semi. Evil or Very Mad
PostPosted: Fri Dec 23, 2011 7:16 pm    Post subject: Re: Official Non-ICD marker discussion thread
your HPR is VERY high. Looking throught he marq section on PBN, i'm finding that all the engines run on about the same settings.
LPR around 70 PSI
HPR around 170PSI
Dwell at 6ms
Chances are, you need to clean and lube it all, or change your dwell, you never stated what it was at. When you lube it, use dow33 on all the inside bits, and DOW55 of the outside orings of the engine so they create a steal betweenthe engine and the body of the marker. then use paintball oil on the orings on the bolt itself.
Make sure that the two holes on the engine are lined up with eachother, and face the bottom of the marker. These are the LP air holes and if they aren't lined up right, you'll obviously have issues:)
you gotta back the "wedge" out as much as possible to get a rotor on the stock feedneck. also twist it counter-clockwise or the "wedge" will catch and you won't be able to get in on.
Your billow bolt doesnt' have a quick disconnect on it? That really sucks. Try using heat and vice grips
here's a good read
www.pbnation.com/showt...?t=2738642
PostPosted: Fri Dec 23, 2011 7:47 pm    Post subject: Re: Official Non-ICD marker discussion thread
I was able to rick my dwell at 4. And yeah, your pressures seem high.
And that doesn't make sense that it doesn't fit a rotor. Like matrix said, adjust out the wedge.
The bolt should have a QD on the actual poppit stem. Post up a pic.
As far as a trigger, go with a violent.
And yeah, the stock grips are awful...
PostPosted: Sat Dec 24, 2011 2:02 am    Post subject: Re: Official Non-ICD marker discussion thread
bah, all BL guns suck. its just that they come all cut and carved, and he releases one every month to keep up with the kids of PBN. Wink
PostPosted: Sat Dec 24, 2011 2:39 am    Post subject: Re: Official Non-ICD marker discussion thread
you shut your mouth.
PostPosted: Sat Dec 24, 2011 3:01 am    Post subject: Re: Official Non-ICD marker discussion thread
mouth is shut, its the fingers, the fingers i tell ya!
butternutvalley
PostPosted: Sat Dec 24, 2011 3:48 am    Post subject: Re: Official Non-ICD marker discussion thread
Took it to work tonight since wasn't planning on actually working and worked on getting the pillow bolt off. Finally came off,just extremely tight fit. Was new, still in package.
Dwell is 6ms
Yup, holes lined up correctly. Saw that on Mike's techPB video on the closer.
Read through that thread and others the last couple days.
As far as getting rotor on did all that and still couldn't beat it in with a hammer. Ask Dalton, he was getting a chuckle out of watching me try.
Checked with veniers and rotor feedneck is .010 bigger than opening.
Gonna have to sand a little. Didn't want to have to do that.
butternutvalley
PostPosted: Sat Dec 24, 2011 4:35 am    Post subject: Re: Official Non-ICD marker discussion thread
Hey, shouldn't your fingers be working on my harness young man. Laughing
PostPosted: Sat Dec 24, 2011 6:27 am    Post subject: Re: Official Non-ICD marker discussion thread
bah, all your electronics belong to me!
Page 2 of 67
adidas solar glide st 3 rosse
Last post by igo5apzv in Calendar of Events on Oct 22, 2020 at 02:08:20
adidas solar glide st heren
Last post by igo5apzv in Off Topic on Oct 22, 2020 at 02:05:46
adidas solar glide 19 negras
Last post by igo5apzv in Paintball talk on Oct 22, 2020 at 02:02:12
Last post by Tzarector in ICD Gear Forum on Oct 15, 2020 at 13:24:07
new balance 1530 saldi online
puma italia scarpe
onitsuka tiger chaussures
Last post by Johnonsmith in ICD Mech Markers on Sep 17, 2020 at 08:19:53
Huh?
Last post by Un2XS in PRP General Forum on Sep 16, 2020 at 06:33:40
Line SI Promaster
Last post by Un2XS in ICD Mech Markers on Sep 16, 2020 at 05:53:58
Classic Fox Sold On MCB
Last post by Un2XS in ICD Mech Markers on Sep 16, 2020 at 05:30:01
