Visitors: 207
Total: 207
118: Your Account
156: Photo Gallery
160: Photo Gallery
187: Photo Gallery
189: Photo Gallery
198: Photo Gallery
205: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Bad pred lite board? :: Archived
PostPosted: Wed Jan 18, 2012 5:19 am    Post subject: Bad pred lite board?
I have been working on a NDFS7 I picked up on PBN for the last few weeks. I did not really go over it when I bought it since it was/is getting torn down and fixed up. It will be getting all the nice goodies a freestyle deserves.
Now, the problem: I went to test out the harness and the noid did not click. Shenanigans. So I tried another battery and another board. The noid clicks with a different board.
So, it appears that I have a predator board that lights up, adjusts, pins are intact, but it does not make the noid work? Has anyone experienced this before?
PostPosted: Wed Jan 18, 2012 8:00 am    Post subject: Re: Bad pred lite board?
you could put a tester to the pins while plugged in to see if the noid is getting enough juice. test a different battery with the Pred lite and see if that changes anything.
PostPosted: Wed Jan 18, 2012 12:41 pm    Post subject: Re: Bad pred lite board?
I know you are smarter than this, but I'll say it anyway. did you check the dwell? I have encountered a few where dwell was at 1 or 2, and no clicky. Other than that, I dont think I have ever run into a pred that did not work.
PostPosted: Wed Jan 18, 2012 5:33 pm    Post subject: Re: Bad pred lite board?
Steve, this is the famous board that Tom's daughter dumped out, ended up in the sink, under water that sat in some rice in an attempt to save it.
PostPosted: Thu Jan 19, 2012 3:10 am    Post subject: Re: Bad pred lite board?
^Actually, that is a different board that works perfectly now. And it was my grandmother in law that dumped it. Shesh. I did try a different battery though. That was my first thought.
^^But I am not smarter than that. I will check the dwell. God only knows what people had done with it after you traded or sold it.
PostPosted: Thu Jan 19, 2012 5:00 am    Post subject: Re: Bad pred lite board?
Hahahaha. Yup. The previous user must have had the dwell and the debounce backwards. The debounce was set to 14 and the dwell was set to 1.
PostPosted: Thu Jan 19, 2012 7:26 am    Post subject: Re: Bad pred lite board?
goody goody gumdrops. another board saved. someone should try and contact Spittlebug about the reflashing project and see where it is. blew in there like a storm and left just as quickly.
PostPosted: Fri Jan 20, 2012 3:24 am    Post subject: Re: Bad pred lite board?
You can find him in the voided warranty and custom marker subforums on PBN I think.
PostPosted: Fri Jan 20, 2012 3:34 am    Post subject: Re: Bad pred lite board?
he also lurks on Manike's and TechPB forums. almost everywhere but here... makes you wonder. do Canuck ears burn, when you talk about them?
PostPosted: Fri Jan 20, 2012 3:35 am    Post subject: Re: Bad pred lite board?
I guess we will find out.
