Visitors: 59
Total: 59
44: News
Forums › General › Paintball talk :: Archives › Bob Long Defiant :: Archived
Bob Long Defiant
spaz66
PostPosted: Thu Jan 26, 2012 11:28 pm    Post subject: Bob Long Defiant
I just received this marker,Im wandering if someone knows a little about it,the board reads ICD 8200,and the noid has a sticker on it that reads Indian Creek Designs 982030.The marker has a leak,ive taken out the noid and cleaned the piston and relubed it,but the leak is still present,the marker will shoot even with the leak im wandering if anyone knows any info on this beast.
Together we will win
PostPosted: Thu Jan 26, 2012 11:40 pm    Post subject: Re: Bob Long Defiant
Stock Deffy with a Ripper Frame, Lapco Vert and old school VW Rock adapter. Where's the leak from? Might check the orings on the ram housing, and the ram piston oring. After that, I would check the orings between the manifold and body.
KPCSpb
PostPosted: Thu Jan 26, 2012 11:43 pm    Post subject: Re: Bob Long Defiant
Can you tell where the leak is located at or what area the leak is ?
Ken W
I'm just a glorified drill press operator.
spaz66
PostPosted: Thu Jan 26, 2012 11:53 pm    Post subject: Re: Bob Long Defiant
it sounds like its from above the noid,around the block the noid is screwed into
KPCSpb
PostPosted: Thu Jan 26, 2012 11:57 pm    Post subject: Re: Bob Long Defiant
There is a O-ring in between the body & manifold.
There is a gasket in between the noid and manifold.
I would check both of these to make sure they are making a sealed.
Ken W
you need to eliminate the ram orings first, because if the center oring on the housing or the oring on the ram shaft is nicked, it will cause the solenoid to vent out of the exhaust. Also make sure your LPR is not set too high, as that will cause the solenoid to vent.
Edit: what Ken said, too.
spaz66
PostPosted: Fri Jan 27, 2012 12:01 am    Post subject: Re: Bob Long Defiant
kk will check it,Stock Deffy ? not up on the terminology,guy at the paintball shop seen i run a promaster and thought i might be interested in this marker and gave me an awesome deal.
PostPosted: Fri Jan 27, 2012 12:05 am    Post subject: Re: Bob Long Defiant
Deffy = Defiant. Bob Long variant of the Bushmaster. Yours has some nice upgrades for it's day.
PostPosted: Fri Jan 27, 2012 12:11 am    Post subject: Re: Bob Long Defiant
Deffy = short for Defiant
Defiant where Private Label Bushmaster 2000 made by ICD for Bob Long before the Intimidator was made.
that is a great looking gun, with a lot of choice parts, though on the older side, but still good.
you have the a stock board, which isn't bad, semi, 3, 6, full auto(semi is unlimited, but 3,6,FA is limited to 9). my first thing is to upgrade the harness, but i'm biased about that Wink
spaz66
PostPosted: Fri Jan 27, 2012 12:13 am    Post subject: Re: Bob Long Defiant
Thanks ill get to work on it and post back when i get results,ram housing is very dry and dirty so possibly just some tlc and lube and it will be ok o-rings are in good shape,ram slides smooth without too much resistance just like my PM.
