Visitors: 94
Total: 94
28: Home
36: Home
75: Home
87: Home
88: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › CRCB noid :: Archived
CRCB noid
PostPosted: Tue Jan 31, 2012 10:14 am    Post subject: CRCB noid
i'm fixing this FSP and one of the problems was that the noid wires are just falling apart, so much that i'm about an inch away from the noid itself. now, i'm pretty good at soldering and figured i take off the blue cap and desolder the old pos & neg wires and put on some new pieces.
well, getting off the cap was an adventure, but i got it off. i tried to desolder the post that hold the board on the noid, but somehow i was thinking it just popped off. well its not supposed to. so the 2 incredibly thin copper wires broke off. i did resolder the new wires on, but after that, i tested the noid and its dead.
so, is this totally F'ed, or can i actually fix this? i have a replacement HEA, so the gun will be working again, but i do know that i will have to replace the noid with a CRCB, regardless.
PostPosted: Tue Jan 31, 2012 11:50 am    Post subject: Re: CRCB noid
You might need to take it apart and make sure the copper wires are not broken somewhere else. i have had luck fixing the coils on 4 now, mainly the ego ones, so you should be able to get it working again. If not, and you want to get rid of it for the parts, I can use it...
