Overall: 7911
Visitors: 118
Total: 118
25: Your Account
34: Your Account
84: Groups
97: Home
104: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › big freakin prob with my bko :: Archived
red04bkoowner
PostPosted: Tue Apr 06, 2004 5:56 pm    Post subject: big freakin prob with my bko
my 04 bko will not fully re-cock all the way when i pull over 3-4 bps the bolt /ram arm will not return fully to the cocked position befor the next shot is fired so the balls will not feed(works fine when shooting slow).....any suggestions??..... i know for sure its not my bolt or the two screws in the back that hold the ram assembly on becuse i called icd and thats the only two things that they told me to check and i did......also when i hook my gun up to an air compressor (125 psi) it works fine but when i screw in the tank i get this problem so please help me cuz i dont wanna use my jt 6.0 this weekend when i go paintballing!!!
-ProDigY-
PostPosted: Wed Apr 07, 2004 5:47 pm    Post subject:
It's your ram.
You'll want to loosen the set screw and push the metal rod in as much as you can. You may or may not hear a little "click".
This should fix it. Also wouldn't hurt to loosen the two screws on either side of the ram a little, too.
red04bkoowner
PostPosted: Thu Apr 08, 2004 4:54 pm    Post subject:
im not quite sure what your saying can you explain some more on this?
Monke
PostPosted: Thu Apr 08, 2004 4:55 pm    Post subject:
the two screws on the side of your gun near the back of it might be too tight.
Embrassing...no one realized that the sniper was sitting in that tree the whole time....
vc style....
DarrylHadfield: hehe.. American Beer.. is like sex in a canoe.. F**king close to water!
red04bkoowner
PostPosted: Thu Apr 08, 2004 7:51 pm    Post subject:
is that the set screws "prodigy" was talking about?
i know its not those because i tried lossening them already because thats the first thing icd told me to do when i called them
Monke
PostPosted: Thu Apr 08, 2004 7:53 pm    Post subject:
i believe those are the ones Prodigy is talking about.
vc style....
red04bkoowner
PostPosted: Thu Apr 08, 2004 8:14 pm    Post subject:
do u know anything about the pushing the ram all the way till it clicks thing he was sayin?
Monke
PostPosted: Thu Apr 08, 2004 9:03 pm    Post subject:
yea i think he's talking about the set screws that trips the microswitch in your grip. The top screw on your trigger might have loosened and screwed itself into far and is not activating the microswitch causing your gun to fire once and then the led will stay on but the screw is keeping the microswitch not allowing you to cycle. the very bottom screw sets how far your trigger travel is that too could have become loose and isn't allowing enough room for your top screw to trip the microswitch. the middle screw is your spring tension that you can leave alone for now.
my suggestion is to loosen the very bottom screw on your trigger and then the top one...
cheers
vc style....
-ProDigY-
PostPosted: Fri Apr 09, 2004 3:40 pm    Post subject:
Er, no.
Sorry, i didn't realize how vague i was in my post....
Okay, here's what you need to do:
First of all remove the ram assembly completely from your gun...this will just make it easier to work on. You're going to want to remove the solenoid from your ram; underneath it there will be a set screw which you will want to loosen with about two turns.
What you want to do next is push the hammer and the ram housing together. You may or may not hear a little click when you've done this, but you'll probably feel or see the ram sleeve+hammer going into the housing.
Afterwards, just put it all back together. Make sure the set screw is reasonably tight, but make sure not to overtighten it.
This should do the trick.
