Visitors: 166
Total: 166
74: Home
118: Surveys
119: Home
120: Your Account
126: Home
127: Home
145: Home
Forums › Marker Talk › Problem/Tech forum › Bushmaster wont fire
junior24
PostPosted: Thu Apr 19, 2012 10:34 pm    Post subject: Bushmaster wont fire
Ok, so I aired up my backup marker and tried to fire it. All I got was a click. The gauge reads 350 psi and the bolt cocks back. I took off the trigger frame and pressed the gray button on the noid and it fired. Can some help me?
capitalp
PostPosted: Thu Apr 19, 2012 10:40 pm    Post subject: Re: Bushmaster wont fire
you said it clicks? but is that the trigger switch clicking or the noid.
try a battery first then check the wires to the noid.
PostPosted: Thu Apr 19, 2012 10:57 pm    Post subject: Re: Bushmaster wont fire
drop the pressure 100psi. you should be around 200psi.
check the wires from the microswitch, and the wires to the noid. put a good, fresh battery.
junior24
PostPosted: Thu Apr 19, 2012 11:16 pm    Post subject: Re: Bushmaster wont fire
I'll try it tomorrow I need more air. It has a fresh batt.
dyn2liv
PostPosted: Fri Apr 20, 2012 9:38 am    Post subject: Re: Bushmaster wont fire
Is this a blind marker?
lexiones
PostPosted: Fri Apr 20, 2012 10:38 pm    Post subject: Re: Bushmaster wont fire
check it again!!!!
Sorry worked as a tech for a long time. I learned to not trust anyone with that answer. It's not just you.
Does your board have a dwell setting?
Try it withough air. Do you hear just a click from the trigger or do you also hear a click from th solenoid. an easy way to tell the difference is to fire with the gun off and then turn it on and fire it. when turned on you should hear the click from the frame and the tray at the same time.
did you hear a small puff of air when you had it gassed up and fired?
junior24
PostPosted: Sun Apr 22, 2012 6:23 pm    Post subject: Re: Bushmaster wont fire
took apart the solenoid cleaned and lubed and it fires now, but I broke the battery wire to the on/off switch when putting it back together.
PostPosted: Mon Apr 23, 2012 1:22 am    Post subject: Re: Bushmaster wont fire
either you can just solder it on(if you know how to) or send it to me. $4 paypaled and shipped.
junior24
PostPosted: Mon Apr 23, 2012 3:42 am    Post subject: Re: Bushmaster wont fire
yea, I just need to get up and do it...lol thanks.
