Latest: NisaDisco
Overall: 7919
Members: 1
Visitors: 184
Total: 185
 Members:
01: Dillankid > Forums
24: Your Account
28: Home
69: Your Account
81: Home
82: Home
85: Home
90: Home
92: Your Account
98: Home
101: Home
106: Home
125: Home
137: Home
139: Home
156: Home
157: Home
183: Photo Gallery
Forums › Marker Talk › Problem/Tech forum › Freestyle FS-7 Help
Freestyle FS-7 Help
Go to page Previous  1, 2, 3, 4  Next
JBacon
PostPosted: Fri Jun 08, 2012 7:11 pm    Post subject: Re: Freestyle FS-7 Help
ok, so i got the right o-rings today (Thanks Peters!!) and it is much harder to put in then the buna ones. with the marker i got the original parts kit and it included one of these o rings (not in buna) and when i went to put it in, it broke on me. i don't want the same thing to happen to these new ones, anyone have tricks on putting these in?
Thanks in advance.
**Edit: i also have no air, but will be at a field tomorrow (all day air pass) so i can try some other stuff then.
2k Cocker pump
05 Freestyle fs7
PostPosted: Fri Jun 08, 2012 7:51 pm    Post subject: Re: Freestyle FS-7 Help
They are a real pain in the but to get in. You have to stretch them a bit in the process of putting them on. Try warming them up a bit? I usually end up taking the valve pin out, but the valve pin is supposed to be loctited in.
PostPosted: Fri Jun 08, 2012 7:53 pm    Post subject: Re: Freestyle FS-7 Help
The poly rings are a pain to get on I broke one on mine too. You have to be pretty careful. I use a little lube and an allen or a blunt punch to push it on the stem. Just don't nick it or you'll have to do it all over again.
The bigger orings are .017 viton that I used on the bolt and the guide(inside) to reduce friction.
Shown here: www.icd-owners.com/htm...ic&t=16626
Glad they got there so quick.
JBacon
PostPosted: Fri Jun 08, 2012 10:56 pm    Post subject: Re: Freestyle FS-7 Help
well, the valve pin is loctited in, how should i go about taking it out? or how would i go about warming the o ring up? microwave, or steam from boiling water, may be heat it in water?
I put one of the bigger o rings on the inside and almost feels better when i move it by hand. im glad they got here quick too. i am hopefully going to play tomorrow, and its been too long sence the freestyle has been used.
2k Cocker pump
05 Freestyle fs7
PostPosted: Sat Jun 09, 2012 12:43 am    Post subject: Re: Freestyle FS-7 Help
The only way I would think of heating it up would put it in a cup if warm water for a minute. I've never done it but it's probably be the safest way.
Maybe someone here could chime in on that.
JBacon
PostPosted: Sat Jun 09, 2012 1:36 am    Post subject: Re: Freestyle FS-7 Help
Sweat! tried this and it worked beautifuly. going to the field tomorrow to try it out. Thanks a ton to everyone who helped
Edit** Went to the field and it felt great was good to play with this again. i will most likely have it for sale, within a few weeks. thanks
2k Cocker pump
05 Freestyle fs7
JBacon
PostPosted: Thu Jun 21, 2012 5:45 pm    Post subject: Re: Freestyle FS-7 Help
alright another problem has occured. for some reason, the hpr is leaking out of the ajustment screw on the bottom. any ideas??
2k Cocker pump
05 Freestyle fs7
PostPosted: Thu Jun 21, 2012 9:41 pm    Post subject: Re: Freestyle FS-7 Help
HPR piston o-ring. Don't know what size it is off the top of my head, but it's darn close to a tank o-ring, either an 014 or 015.
PostPosted: Thu Jun 21, 2012 11:16 pm    Post subject: Re: Freestyle FS-7 Help
015, preferably urethane. But buna will work for a bit.
JBacon
PostPosted: Sun Jun 24, 2012 12:58 am    Post subject: Re: Freestyle FS-7 Help
awesome thanks guys. also another thing, i think i may have blown the solenoid or something, but when i pull the trigger with a ball in chamber, it blinks but dosen't shoot (using a different reg) and same thing with eyes off.
any ideas? i did recently adjust the trigger pull, to make it longer, could that have done it?
thanks for all the help guys, i appreciate it sooo much.
2k Cocker pump
05 Freestyle fs7
Page 3 of 4
Nike Air Max 90 zu seiner
asics scarpe basso prezzo
basket adidas femme pas cher
nike air max 2090 hombre
