Latest: Osweiler
Overall: 7925
Visitors: 184
Total: 184
99: Home
128: Home
135: Your Account
153: Home
158: Home
163: Photo Gallery
168: Photo Gallery
173: Photo Gallery
182: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › vapor valve operating pressure and installment :: Archived
Jetpak101
PostPosted: Mon Oct 06, 2003 8:22 pm    Post subject: vapor valve operating pressure and installment
I have ordered a vapor valve for my 2k3 BKO. Is it hard to intall, does it come with instructions, or where can I find out how to install it? Also, with that valve and the stock reg, what will my operating pressure be? I was running 175psi with about 260-270 bps. I figure the valve will lower the psi but by how much and will I see a noticeable difference in efficiancy? Thanks for the help! Very Happy
Black 2k3 BKO
Shocktech med. drop and rail adaptor
Vapor valve
16" DYE Ultralite
Crossfire 88ci 4500psi phat low preset
12v revvy with x-board
PostPosted: Mon Oct 06, 2003 9:12 pm    Post subject:
well u take out the valve as normal then put the new one in. You need to isolate the body, then take out the little brass screw on the bottom of the body, then grab somehing long and thing and push the valve out of the front. then put the new one in the same way but backwards.
dval
PostPosted: Mon Oct 06, 2003 9:21 pm    Post subject:
you can also go to vaporks web site and i believe the intructions are posted, if not contact goldie and he can give them to you
Doc
PostPosted: Tue Oct 07, 2003 3:18 pm    Post subject:
It would be best if you get a Vapor Valve cap or VBW's BKO Valve Cap, to go along with the Vapor valve.
The most efficient pressure is approx 190psi.
I've been able to get it down to 125psi shooting 270fps. I took out the internals of the LPR but left the piston in place so that the LPR body acted as a simple flow through. I set the HPR to 125psi and it was chronying at 270fps.
Cheers
Lion's Pride www.lionspridepaintball.com
CPPA #1278
B2K4 PDS, Vapor Valve, AKA Sidewinder, AKA SCM 3, 2k7 Chaos
2k3 Black BKO, Modified stock Valve, AKA Mitey Max, Zenitram BKO ASA adaptor, Palmer Stabilizer/Micro-rock, 2k4 Chaos
06 SGM WRX Wagon
Sangerpb
PostPosted: Thu Oct 09, 2003 12:48 pm    Post subject:
haha, how many shots do you get per tank, go to the technical bushy section and check my teardown of the 2k3
Keo
PostPosted: Thu Oct 09, 2003 4:13 pm    Post subject:
but the 2K3 and the Bko is somewhat different, like there's 2 screws for the asa, but everything else is the same
Doc
PostPosted: Fri Oct 10, 2003 10:16 am    Post subject:
Proraptor wrote:
you probably get 10 shots per fill running your hpr at 125psi....lol
Yep. It looks impressive to run the BKO at 125psi. Very quiet. But well... efficiency.... at least with the setup I was trying out..... is about what you've described :S
Cheers
CPPA #1278
06 SGM WRX Wagon
Sangerpb
PostPosted: Fri Oct 10, 2003 11:16 am    Post subject:
lol 15bps and one hopper, then no more air!
Mike Tomlin implies there is a trong possibilitythe Steelers
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:45:00
Packers stay on offense, add RB A.J. Dillon
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:44:39
For 2nd straight season, Seahawks offense struggling to fly
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:44:12
Chiefs welcome fresh/outdated faces inside of Allen
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:43:58
Run defense issues highlight total breakdown for Saints
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:43:15
Pitch and catch: Round 2 of NFL draft heavy on receivers
Last post by Osweiler in Off Topic on Nov 26, 2020 at 03:42:37
Corridor of Fame QB Jim Kelly suggests checks demonstrate re
Last post by Osweiler in Paintball talk on Nov 26, 2020 at 03:42:15
How do you hit pictures in NBA2K21?
Last post by wfuuopy in Off Topic on Nov 20, 2020 at 01:53:02
RuneScape is Free-To-Play
Last post by wfuuopy in Paintball talk on Nov 20, 2020 at 01:52:09
If You Are Clever About It
Last post by Kingang in Off Topic on Nov 18, 2020 at 10:05:37
