Visitors: 76
Total: 76
74: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › solenoid screw problem :: Archived
Go_Pokes_Go
PostPosted: Mon Apr 19, 2004 1:53 am    Post subject: solenoid screw problem
after shooting my bko (it's an 03) for a little bit the solenoid screws loosen up and it starts leaking (started doing this the other day). so i tightened them back up and they came loose again after not very many shots. so i put some blue loctite on the screws, the next day i go to a little local tourney and the gun works fine until the middle of the last game the screws start to come untightened and it leaks a little, not enough to prevent me from playing till i got hit though.
now i didn't put too much loctite on the screws when i did it the first time, so put a bit more the second time, i haven't tried firing it yet (put the loctite on earlier today and am giving it time to set and whatnot).
i was wondering if there is another way to deal with a problem like this and if anyone else has experienced this problem.
thanks in advance
Stark
PostPosted: Mon Apr 19, 2004 3:24 am    Post subject:
Try here
I can´t think of anything witty right now
Go_Pokes_Go
PostPosted: Tue Apr 20, 2004 3:22 pm    Post subject:
the rubber piece between the solenoid and ram is fine, it leaks when the screws come undone. they (the screws) work themselves out when i shoot.
Stark
PostPosted: Wed Apr 21, 2004 2:25 am    Post subject:
Yeah, the threads on the screw are going. You need to replace them. May as well replace the gasket as well... or at least youll have a spare on hand.
PostPosted: Wed Apr 21, 2004 7:27 am    Post subject:
Um, no they are not. The screws and gasket are fine. You just need to use a little more loctite and give it a day to cure. If you find it still doesn't work use very little red loctite.
I had the same problem when i first got my BKO, but after i broke the marker in, there was no problem.
