Visitors: 99
Total: 99
34: Your Account
36: Your Account
67: Home
88: Your Account
Forums › Buy/Sell/Trade › ICD Gear Forum › Nameless ICD parts Store
Go to page Previous  1, 2, 3, 4, 5  Next
Post new topic   This topic is locked: you cannot edit posts or make replies.   Printer Friendly Page     Forum IndexICD Gear Forum
kwik
PostPosted: Thu Feb 14, 2013 9:39 pm    Post subject: Re: Nameless ICD parts Store
awesome, I will be hitting ACE tomorrow during lunch......or maybe on the way home =P
edit: Went and got a cpl, theirs were labeled 3/8-16 and seem the fit fine size wise but the threading on the screws looks thicker than that in the bolt, I dont want to mess anything up so I may see if Home depot or someplace has them in a smaller thread.
kwik
PostPosted: Sat Feb 16, 2013 12:52 am    Post subject: Re: Nameless ICD parts Store
Ok here is the findings:
The set screw is 3/8 - 24 by half inch long or so
The stock ball bearing is also too small, it falls through into the bolt pin shaft, I will post the size I end up using tomorrow when I get to the store.
This will end up being nice as I can leave the stock boot together now.
PostPosted: Sat Feb 16, 2013 5:38 am    Post subject: Re: Nameless ICD parts Store
hmmm, one idea has failed, but i'll try to check out ACE for a better fitting ball bearing. this will increase the cost if i do include them for the bolts.
PostPosted: Sat Feb 16, 2013 12:46 pm    Post subject: Re: Nameless ICD parts Store
I successfully used an airsoft pellet in one my my bushmaster bolts. it's nearly the exact same size.
lexiones
PostPosted: Sun Feb 24, 2013 3:25 am    Post subject: Re: Nameless ICD parts Store
Just fyi the bolts are nylatron (GSM i believe). Its one of the best materials for bolts because of it's wear resistance but a ***** to take off the burrs after it's machined. That's why the areas around the holes and edges look a little weird. Also expect the holes to be a little smaller then when they were initially machined. Mine had to be drilled out a little bit for the bolt pin. But, that was done easily with a drill gun. Everything else worked great with it though.
Get off the internet I need to use the phone!!!!!!!
kwik
PostPosted: Sun Feb 24, 2013 12:57 pm    Post subject: Re: Nameless ICD parts Store
your stock bolt set screw worked in the nameless bolt? Mine is too small by a long shot and ace and home depot dont carry them in the proper size, I will probably be ordering them online soon.
PostPosted: Sun Feb 24, 2013 4:15 pm    Post subject: Re: Nameless ICD parts Store
let me check again. might have the proper bolts and are assuming for the size. i'll grab a few bolts and narrow down the size AND get the proper size. anyone who has gotten a bolt and no screw(or parts), i'll send out the parts, for free.
thespawn078
PostPosted: Thu May 30, 2013 1:33 pm    Post subject: Re: Nameless ICD parts Store
I am interested in a black annodized Freestyle trigger. Please let me know if/when this could be done. I just purchased an FS7 and I'd really like to upgrade the trigger with this style. Thanks!
PbN Feedback: www.pbnation.com/feedb...p?u=366950
MCB Feedback: www.mcarterbrown.com/f...dback.html
ICDO Feedback: www.icd-owners.com/htm...202#119202
PostPosted: Thu May 30, 2013 4:51 pm    Post subject: Re: Nameless ICD parts Store
they should be back next week. will update when i get them.
lexiones
PostPosted: Tue Jun 25, 2013 8:40 pm    Post subject: Re: Nameless ICD parts Store
Just an FYI. The first post is a little %20'd
Post new topic   This topic is locked: you cannot edit posts or make replies.   Printer Friendly Page     Forum IndexICD Gear Forum All times are GMT - 7 Hours
Page 2 of 5
