Visitors: 120
Total: 120
32: Your Account
70: Your Account
Forums › General › Off Topic › HI guys(and gals if any are around)
Go to page Previous  1, 2, 3
PostPosted: Fri Aug 19, 2016 4:07 pm    Post subject: Re: HI guys(and gals if any are around)
What kind of trigger are looking for? I have for PM/FS: stock, Lasoya, Pro trigger, Nameless reverse S, but not the ND trigger or a CP(that i know of).
So anything else you need, LMK.
PostPosted: Wed Aug 24, 2016 8:50 am    Post subject: Re: HI guys(and gals if any are around)
Hey Nobody, good to hear from you. Do you have any PM triggers with the bearings? I have found a Lasoya trigger from my LPM, I think. I had a CP trigger that I really enjoyed but I think I actually sent it when I sold my LPM and NDFS7. Man I miss those two.
Anyways, I'm not a huge fan of the trigger I found and wouldn't mind grabbing one annoed black from you along with one of your bolts if you still have them. The reverse S would be great as that would more closely resemble the CP and it would send money your way instead of ANS. I really loath them. I had a deal with them a couple years back when I was playing all the time for an Edge barrel kit. They ran out and told me they were waiting for stock. Three months later and I still had no barrel kit, no emails, and no conversation what so ever from them. In the end it took close to 4 months total to send me the kit but only after some lawyerly advice and some convincing from my end. So if I can buy them from you instead that would be great.
Also, I have the Humphreys HEA10A5-GL-101W and a HEA10F5-GL-101W (with barbs), are the mids of this solenoid interchangeable? If that isn’t clear which it probably isn’t. I have two functional noids, however one is sticky sometimes and it is the one with the barbs and is from a PM. The other I have is from a Bushmaster and doesn’t have barbs but has the gasket. Would I be able to change out the middle sections where the barbs are or do these two have different passages where the air goes?
Thank you in advance for your help.
Andrew
[/size]
My Feedback www.icd-owners.com/htm...mp;t=11141
sometimes i wish i would get fired. You know that feeling there is something else you should be doing and don't have the cojones to go find something else? plus working for your dad is a major drag.
I DO love the color. The pictures don't do it justice. If you are not getting a chub looking at the pictures then you are not getting the full effect. This color is why Viagra pills are blue.
PostPosted: Wed Aug 24, 2016 1:28 pm    Post subject: Re: HI guys(and gals if any are around)
I gladly will take your money for a trigger. Though i have had only 1 problem with ANS(sent the wrong size barrel, which i kept instead of playing mail tag), i tend to use them as a last resort. More importantly, do you have the trigger pin? I do have them, which i can include.
Yes on the noid, as long as they are from the same manufacturer, the parts are interchangeable. Just be careful and meticulous on disassembling them. There are tiny parts in there, if you haven't taken on apart. My advice, take the sticky noid apart, inspect the spool. It could be a simple lack of lube. But lay it out in order, remembering where each piece goes.
Just for edification. On the Humprey sticker. You have manufacturer(HEA), model number(10 series), placement or position(whether it takes gaskets or barbs) and the wattage rating or something like that. Though, i do suck at noid maintenance if i am lucky i can save 50% of the bad noids I've come across.
PostPosted: Wed Oct 19, 2016 9:33 pm    Post subject: Re: HI guys(and gals if any are around)
So I've been busy selling wine and spirits... Gearing up for my busy season. Someone looking for some wine?
Page 3 of 3
