Visitors: 74
Total: 74
47: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › makeshift vapor bolt question..... :: Archived
pbjunkie87
PostPosted: Tue Apr 06, 2004 1:05 pm    Post subject: makeshift vapor bolt question.....
Hey, i have a stock BKO w/ a PE 47 ci 3000 psi tank and a 2 vt revvy (soon to be an Egg w/ y-board)....i chop like u wouldn't believe....i am getting the egg as soon as i have the money, so i think that that might take care of the problem....then last night, i discovered i have blowback...i discovered that i did by using the card-on-the-feed-neck check(u know, u put a ball in the breech, then put a credit card or something similar on top and when u shoot it and the card competley blows off, then u have blowback).
i was wondering....does anyone know the trick about cutting ur bolt and making ur own makeshift vapor bolt w/ o-rings? i heard about that and i'm not sure if i wanna risk cutting up my bolt to try it....does it really work? or am i better off just buying a vapor bolt?
Also, please, PLEASE somone: tell me how to "sweetspot" the regs. you need to put it in the simplest form u know how....i think my regs are sweetspotted...
View user's profile AIM Address Yahoo Messenger
red04bkoowner
PostPosted: Tue Apr 06, 2004 6:41 pm    Post subject:
i just did that to my stock delrin bolt on my 04 bko and it works way better than i expected ..... its a way better alternative to crappin out 30 bucks for a new bolt
red04bkoowner
PostPosted: Tue Apr 06, 2004 6:43 pm    Post subject:
before i did the mod when i got my egg i thought the chopping would stop also but it didnt .... you have to be careful not to file it all the way to the hole in the bolt tho
pbjunkie87
PostPosted: Thu Apr 08, 2004 2:29 pm    Post subject:
can u (or anyone else) show me how u did it? I'd appreciate it....
red04bkoowner
PostPosted: Thu Apr 08, 2004 8:03 pm    Post subject:
its going to be very hard to do it if u dont have the special machine (i have no clue wat there called) or at least a drill press. i would not recomend just carving in to your bolt. i have a drill press so i just put the bolt into where a drill bit would go and took a file and held it againts where i needed the groove and let it run till the groove was deep enough. if u do not use a drill or the speacial machine u will not get a very straight or even groove so i do not recomend doing this without a stationary drill.....
if u dont have a drill press u might be able to clamp a electric hand drill to a table and that would be the same basic concept as the drill press but its just a thought
pbjunkie87
PostPosted: Tue May 11, 2004 8:03 am    Post subject:
darn...i thought there would've been an easier way.....
levi333
PostPosted: Tue May 11, 2004 9:05 pm    Post subject:
that "special machine" is a lathe.
Silver BKO3ยด
-CP Reg -12" Silver/Black CP 2pc -Silver Zenitram 45 Magnetic Frame -DYE Carbon Fiber Grips -OTB Blind Bolt -CIP Clamping Rise -AKA Mitey Max -Vapor Valve -Kapp Gauge -WGP Torpedo Drop
soap_shoes
PostPosted: Wed May 12, 2004 2:25 pm    Post subject:
or a dremel.....
2k3 silver bko[]male palmers stabe[]halo b[]vapor 2 bolt[]red valve[]microswitch screw mod.[]pds
View user's profile Send e-mail AIM Address MSN Messenger Yahoo Messenger
