Latest: hongwei28
New Yesterday: 1
Visitors: 72
Total: 72
25: Groups
26: Home
70: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › ram pressure unstable w/ rock installed :: Archived
Lee
PostPosted: Tue Jun 08, 2004 4:56 pm    Post subject: ram pressure unstable w/ rock installed
hi all!
here's my issue:
with a palmers hoseless rock installed, the pressure shown on my ram guage is unstable. swings back and forth erratically. this is using a stock 2k3 reg and a palmers satbilizer.
with the stock lpr, the pressure is steady and consitent.
my set up is a b2k3, zenitram valve, vapor bolt, agd flatline 68/3k. output pressure from the flatline can be anything and this will happen. i normally run 600 psi from the flatline.
i have a sidewinder on order and should be here this week and i hope this helps as i'd love to be able to use the rock but havn't lately due to the creeping problem.
also, with the rock installed, i can only get to about 250 fps before the solenoid vents and i ca't seem to gte the pressures right with either reg when using the rock.
this is obviously an issue with the rock, but what am i doing wrong if anything? how can i fix this issue?
thanks!
Lee
Harbinger
PostPosted: Fri Jun 11, 2004 9:39 am    Post subject:
how many shots has the rock seen?
View user's profile Visit poster's website ICQ Number MSN Messenger
www.bengalscheapshop.com
Last post by hongwei28 in Calendar of Events on Mar 23, 2019 at 08:16:53
