Visitors: 112
Total: 112
12: Your Account
64: Your Account
85: Home
110: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › Installing Vapor Valve :: Archived
IOwnATippmann
PostPosted: Thu Jun 10, 2004 6:31 pm    Post subject: Installing Vapor Valve
How would one take out the stock valve and replace it with the vapor valve? Thanks a load.
RaGeN_aZn
PostPosted: Thu Jun 10, 2004 6:37 pm    Post subject:
u need to take out the asa, LPR, and the ram...then take off ur tray and unscrew the valve retaining screw. then take something long and skinny like a pencil or a chopstick and push the valve out torwards the LPR hole. then lube up the vapor valve o-ring and install it...remember, the lil tiny hole goes in the gun first.
PBN feedback> www.pbnation.com/showt...287002#pos
RaGeN_aZn
PostPosted: Thu Jun 10, 2004 6:41 pm    Post subject:
o yea, and then re-installs everything back on Razz
IOwnATippmann
PostPosted: Fri Jun 11, 2004 12:47 pm    Post subject:
Ive never taken off the asa before, how do I do that?
Harbinger
PostPosted: Fri Jun 11, 2004 1:37 pm    Post subject:
remove the hpr, and then use the proper allen key to remove the asa
View user's profile Visit poster's website ICQ Number MSN Messenger
IOwnATippmann
PostPosted: Fri Jun 11, 2004 6:07 pm    Post subject:
What would be the better to lube the valve? Lithium grease or silicon spray?
RaGeN_aZn
PostPosted: Fri Jun 11, 2004 7:56 pm    Post subject:
lithuim grease...
Leterrip
PostPosted: Fri Jun 11, 2004 8:46 pm    Post subject:
be careful when you screw the set screw back in to hold the valve in place....there should be NO PRESSURE on the valve from the set screw. if you screw the thing in too tight the valve will LEAK!! just screw it in until it merely touches the valve and that should hold it. just put some locktite or teflon tape around the set screw first to hold it in place since it's "floating there".
bushy86
PostPosted: Sun Jun 13, 2004 9:51 am    Post subject:
make sure u put things back properly, loctite the the valve screw lightly
RaGeN_aZn
PostPosted: Sun Jun 13, 2004 10:20 am    Post subject:
no need for loctite
