Visitors: 69
Total: 69
Forums › Marker Talk › Problem/Tech forum :: Archives › Leak :: Archived
Leak
BigO
PostPosted: Sat Jun 12, 2004 5:18 pm    Post subject: Leak
hey i got a 04 bko. my problem is when i screw in my n2 into my gun. i hear a big leak coming from the back of the trigger frame. i have no idea why. please help. nd also this gun is almost brand new if that helps. i also noticed that 2 screws were lose in the bottom tube in the back. so i just tighted it and loctite those screws. please help. kinda in a hurry
View user's profile Yahoo Messenger
a90876
PostPosted: Sat Jun 12, 2004 6:55 pm    Post subject:
if its anything like my 03 bko, your LPR needs reset and the leak is your 'noid blowing off pressure. Thats just a guess on my part though.... the way i fixed it, was to adjust my hpr to about 280-285, then back out the LPR screw until you hear a soft pop, then run the LPR screw in until you get the gun at the right FPS for wherever youre playing.
Proud owner: Red 2k3 BKO.
Feel free to PM me anytime.
BigO
PostPosted: Sat Jun 12, 2004 7:01 pm    Post subject:
ya but the only prob is i dont have enough time to adjust my regs it leaks so much air
a90876
PostPosted: Sat Jun 12, 2004 7:15 pm    Post subject:
you need an allen wrench or two... this is a 5 minute process... granted im not sure if that will 100% fix your problem, but its 5 minutes... if youve got time to post again, youve got time to at least try
a90876
PostPosted: Sat Jun 12, 2004 7:17 pm    Post subject:
as an addition, my regs were definately making my 'noid leak
BigO
PostPosted: Sat Jun 12, 2004 7:20 pm    Post subject:
no what im trying to say is by the time i get my regs adjusted ill be out of air so i wouldent be able to test it.
a90876
PostPosted: Sat Jun 12, 2004 7:22 pm    Post subject:
ah, i got you now, my misunderstanding. well something to try when you get more air
BigO
PostPosted: Sat Jun 12, 2004 7:28 pm    Post subject:
i forget someone was telling me it might be the noid. but i dont really want to mess with it. im a newb to bkos. u think i should just send it to icd its under warrenty
a90876
PostPosted: Sat Jun 12, 2004 7:44 pm    Post subject:
When the noid gets too much pressure, a built in blow off valve vents the extra pressure so that you dont damage the noid. The problem i was having was from my LPR not working right. I called ICD and they told me to just re-seat the seal in the LPR by adjusting the regs like i said above. it worked well for me, and still works. If youre not sure, just call ICD's tech support, and theyll get you straightened out. like i said though, im not all too familiar with the '04's but it worked for my '03 just fine
BigO
PostPosted: Sat Jun 12, 2004 7:51 pm    Post subject:
ok ill do that probely monday when there open thanks for all your help. so u think all i got to do it reset my regulators?
