Visitors: 214
Total: 214
134: Home
136: Home
159: Photo Gallery
168: Your Account
173: Photo Gallery
176: Photo Gallery
181: Home
184: Photo Gallery
190: Photo Gallery
192: Photo Gallery
195: Photo Gallery
201: Photo Gallery
203: Photo Gallery
Forums › Marker Talk › Problem/Tech forum :: Archives › leak problem :: Archived
leak problem
walker2287
PostPosted: Mon Jul 26, 2004 6:06 pm    Post subject: leak problem
ok i'm very new to bushies and my noid leaks everytime i turn on my air. i turn of my hpr and it doesn't leak but when my lpr screw is backed all the way out and i turn on the hpr it leaks on my noid. i tightened my noid as muchas i could so its not that.
Question
Leterrip
PostPosted: Mon Jul 26, 2004 8:23 pm    Post subject:
put a little dow 33 on the gasket on the noid
gimplar
PostPosted: Mon Jul 26, 2004 10:11 pm    Post subject:
yup, make sure your noid/manifold/gasket assembly is nice and tight with a bit of dow33/dow5 on the gasket to ensure a tight seal. I don't have a bushy myself..I own a BKO, but if there are ram securing screws on the side of the gun make sure they are snug and not over-tightened.
walker2287
PostPosted: Tue Jul 27, 2004 11:42 am    Post subject:
alrite will do. I think the problem is that air from the hpr is getting into the lpr cuz it will work if i have the hpr set around 50psi?
BiggieSMLS
PostPosted: Fri Jul 30, 2004 11:04 pm    Post subject:
hpr around 50 psi???? i hope your talking about your lpr not your hpr... hpr should be around 250
fivestring wrote:
You know kind of like Lite beer....its there it works but wheres the love Very Happy
My boy luke can eat fifty eggs.. ahh why'd you have to say fifty? why not like ten or twenty or thirty?
View user's profile Send e-mail Visit poster's website AIM Address MSN Messenger
PostPosted: Sat Jul 31, 2004 5:50 am    Post subject:
Um the air from the HPR is supposed to get into the LPR. Hpr should be around 225 psi, and LPR, turn it until it leaks then back it out.
I would check the LPR, make sure the piston is well lubed and that the casing is free from debris. I would not touch the noid unless it was absolutely necessary.
Next, if it still leaks, take off the noid, check the gasket for cracks or damage, if there is, replace it. Otherwise put some lube on it and stick it back on, make sure you torque the noid a bit.
Lastly if it still leaks after all this, push the button on the bottom of the noid, if that doesnt work, then take it apart, be careful because there are small pieces. Take the piston out, clean it off, and put lube on it, stick it back in, and now fire it.
Make sure your gun fires before you do all of this, if it doesnt, skip to the noid cleaning, if it still doesnt fire, then your noid may be blown.
ALWAYS CHECK YOUR BATTERY FIRST!!!
