Latest: NisaDisco
Overall: 7919
Visitors: 118
Total: 118
96: Home
99: News
Forums › Marker Talk › Problem/Tech forum :: Archives › where, what, how to regulator :: Archived
CaptianJenkins
PostPosted: Sat Oct 18, 2003 4:10 pm    Post subject: where, what, how to regulator
I just got my BKO 2k3 and i see everyones going crazy over the regulator, and i've looked around and i haven't quite found out what you need to do to it. So i understand use white litium grease only but where do i lube it and how do i adjust it to make it efficent? Pictures are always awesome.
CaptianJenkins
PostPosted: Sat Oct 18, 2003 4:18 pm    Post subject:
also whats a god barrel to get. after fixing my reg and gettign a barrel, any more suggestions?
JesseBryant
PostPosted: Sat Oct 18, 2003 5:11 pm    Post subject:
To lube ur reg u need to pull out the white plunger and put lube on that, it usually takes about 5000 shots to break in the stock regs. Adjust ur stock reg to about 210 psi and u should be all set. The stock regs are picky about lubing them, you should clean it and lube it after everydays play.
Black Bushmaster
Black BKO
b3n
PostPosted: Sat Oct 18, 2003 11:31 pm    Post subject:
You should check around, and see pbreview.com's reviews on barrels. It's only your preference on what barrel you want... the more expensive, the "better." It's all up to you and which barrel suits you. But keep in mind that ICD barrels are pretty hard to find.
Nike Air Max 90 zu seiner
Last post by NisaDisco in Bushmaster General talk on Aug 08, 2020 at 07:47:37
asics scarpe basso prezzo
Last post by NisaDisco in PRP General Forum on Aug 08, 2020 at 07:43:09
basket adidas femme pas cher
Last post by NisaDisco in PRP General Forum on Aug 08, 2020 at 07:38:37
nike air max 2090 hombre
Last post by NisaDisco in Bushmaster General talk on Aug 08, 2020 at 07:34:03
