Latest: Johnonsmith
Overall: 7920
Visitors: 152
Total: 152
46: Home
49: Home
69: Your Account
91: Home
92: Home
93: Home
97: Home
104: Home
115: Home
116: Home
128: Home
132: Home
143: Home
149: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › B2k3 - Slow Recharge :: Archived
Unknownelement8
PostPosted: Mon Aug 30, 2004 6:38 pm    Post subject: B2k3 - Slow Recharge
Well with my B2k3, I'm getting pretty slow recharge rate....
Specs:
Bob Long Torpedo
KAPP DZ3 On/off
Shocktech LPR Plunger
Thats basically the only things that could be causing the problem....
- The Torpedo worked fine on my previous marker
- The On/off is fully on and it did the same with my previous on/off
- The macroline and fittings are all unclogged and free
- The Torpedo is lubed
When I walk the gun, it won't feed becuase the bolt has not came back all the way yet. Even with a single shot, you can see the needle on the guage drop to 0, then back up. Its not my tank either.
I haven't messed alot with Bushmasters, and barely know how they operate...could the plunger be installed incorrectly?
Thoughts?
Last edited by Unknownelement8 on Tue Aug 31, 2004 4:12 pm; edited 1 time in total
Stark
PostPosted: Tue Aug 31, 2004 1:42 am    Post subject:
What pressure are you running your HPR at? It should be 250ish.
I canĀ“t think of anything witty right now
PostPosted: Tue Aug 31, 2004 7:05 am    Post subject:
I've seen this happen with one of two potential sources: a) your LPR's not set correctly, and isn't providing enough pressure to return the bolt to 'rest'; and b) your tank's low on air, which means your HPR won't regulate properly - In fact, I've had that problem with a torpedo elsewhere; they can be a little finicky about not having 950psi input pressure.
So.. double-check your LPR pressure, and make sure you have MORE than 1000psi in your tank.
RaGeN_aZn
PostPosted: Wed Sep 01, 2004 10:28 am    Post subject:
and make sure your ram is lubed properly
PBN feedback> www.pbnation.com/showt...287002#pos
Unknownelement8
PostPosted: Wed Sep 01, 2004 5:55 pm    Post subject:
Well, I lubed my BL torp, got air, and readjusted my LPR.....still nothing.....
Could I have a newb-friendly guide to getting to my ram?
Nator187
PostPosted: Thu Sep 02, 2004 12:10 pm    Post subject:
What kind of gun did you have before? It's gotta be that reg or the tank, what kind of tank is it??
Nator187
www.shootpaint.com www.RedzComfort.com www.Icdpaintball.com www.NitroDuck.com www.BushmasterSource.com
View user's profile Send e-mail Visit poster's website ICQ Number AIM Address
AnOnYmYsBaLLeR102
PostPosted: Thu Sep 02, 2004 4:48 pm    Post subject:
1. Take 4 screws out of the tray and the two out of the manifold( what the regulator screws into.
2. Take out the bolt.
3. Unscrew the two screws that are next to the ram cap( the cap in the back of the gun under the bolt)
someone make corrections cuz im almost positive im wrong since im doing this from a BKO's perspective.
Unknownelement8
PostPosted: Thu Sep 02, 2004 6:49 pm    Post subject:
I had a e-spyder....shot decently fast with it....
I have two tanks, one is a 48ci and the other is a 68ci......I'm unsure on the 48ci brand, but I'm pretty sure the 68 is a crossfire stubby.
Big_Mac
PostPosted: Sat Sep 04, 2004 6:42 am    Post subject:
I've heard a lot of people say 'yeah, I lubed the reg' but did you take it all the way down and check the poly seal in the top half of the reg? If it's cupped or has a 'ring' pressed into it that would cause your problem. Pick up a couple and replace it...cheap insurance.
Stupidity Kills
Toklas
ICD-O Admin
ICD-O Admin
PostPosted: Sat Sep 04, 2004 6:28 pm    Post subject:
welll since you seem to be trying everything might as well try this too. try backing out the on/off so its not all the way on... I've seen some on/off's push the valve pin on the tank so far in that it restricts air from coming out.
an lpr guage would be helpful at this point to see how much pressure is getting to the ram. also I know you said you checked and cleaned the torp but do you have another HPR (maybe a freind) to switch it with just to make sure. at this point I would just start ruleing out what its not. you tried two tanks so most likely thats not it. if you try a couple of HPR's then your positive thats not it. check the ASA passages. check that the ram moves freely. check for leaks around the soleniod, valve, lpr, hpr, ram.
new balance 1530 saldi online
puma italia scarpe
onitsuka tiger chaussures
Last post by Johnonsmith in ICD Mech Markers on Sep 17, 2020 at 08:19:53
Huh?
Last post by Un2XS in PRP General Forum on Sep 16, 2020 at 06:33:40
Line SI Promaster
Last post by Un2XS in ICD Mech Markers on Sep 16, 2020 at 05:53:58
Classic Fox Sold On MCB
Last post by Un2XS in ICD Mech Markers on Sep 16, 2020 at 05:30:01
Last post by Un2XS in PRP General Forum on Sep 16, 2020 at 05:10:57
2K20's demo allows you to build by taking control
Last post by Megaomgchen in PRP General Forum on Aug 17, 2020 at 06:50:58
Madden NFL 20 Highlights Sports Sims Betting Explosion
Last post by Megaomgchen in PRP General Forum on Aug 17, 2020 at 06:50:24
RS3 is nonetheless a good runescape game though
Last post by Megaomgchen in PRP General Forum on Aug 17, 2020 at 06:49:34
