Latest: Skyzhay
Overall: 7947
Visitors: 103
Total: 103
26: Home
28: Home
83: Home
85: Home
94: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › BUSHY WILL NOT DRY FIRE :: Archived
JDmutt
PostPosted: Tue Oct 21, 2003 2:14 pm    Post subject:
i'm relatively new to the ICD/Bushmaster guns but i'll offer my opinion. Just take it as a novice opinion.
I have read that the Bushmaster typically runs at 90psi at the LPR, assuming you are running a stock reg. If you are at 75 the solenoid/ram may not be getting enough pressure to fully cycle. Just a thought, but then again, i'm new to these markers.
Sangerpb
PostPosted: Tue Oct 21, 2003 3:20 pm    Post subject:
if you have pds, you need to turn it off Smile
JDmutt
PostPosted: Tue Oct 21, 2003 3:38 pm    Post subject:
bolt's not in upside down is it? Smile
Keo
PostPosted: Tue Oct 21, 2003 6:45 pm    Post subject:
how are you checking your lpr pressure?
Keo
PostPosted: Tue Oct 21, 2003 7:58 pm    Post subject:
lol, no guage? then it might not be right
Nator187
PostPosted: Tue Oct 21, 2003 9:25 pm    Post subject:
Make sure your putting your bolt pin in right. Remove the ram and make sure it's clean then lube and replace. Turn your lpr up slightly and I went many years with out a gauge so the "Cocker Style" works fine.
Nator187
www.shootpaint.com www.RedzComfort.com www.Icdpaintball.com www.NitroDuck.com www.BushmasterSource.com
View user's profile Send e-mail Visit poster's website ICQ Number AIM Address
Keo
PostPosted: Wed Oct 22, 2003 4:35 pm    Post subject:
it's works but you can not say what pressure your running unless you have a guage
Nator187
PostPosted: Wed Oct 22, 2003 5:36 pm    Post subject:
Not exactly what pressure but you can get a good guess.
Most noids bleed at 100psi, I know not all because mine doesn't bleed until like 130psi, so if you do the cocker way then you know that your pressure is around 80-90 psi if you only turn the lpr down slightly. As long as it takes a good amount of force to push the bolt forward with your hand then your LPR is fine. If you can't even move the bolt it's too high and if you can move it relatively easily then it's to low. A LPR Gauge isn’t needed for a player who doesn’t constantly tweak his gun thus not needed for a novice user.
Nator187
Sangerpb
PostPosted: Wed Oct 22, 2003 6:19 pm    Post subject:
i made my own lpr tester from an old jackhammer Smile
lil_tyrant
PostPosted: Wed Oct 22, 2003 7:10 pm    Post subject:
how did you do that?
Blocks and steals are pretty good
Last post by Skyzhay in Freestyle General Talk on Sep 07, 2021 at 08:33:50
Madden NFL 22: Tight End Ratings
Last post by Skyzhay in Paintball talk on Sep 07, 2021 at 08:32:38
Really appreciated the group facets of dungoneering
Last post by Skyzhay in Off Topic on Sep 07, 2021 at 08:31:33
Chaussures de Nike KD
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 04:08:23
Converse All Star Precio
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 04:05:32
Nike Air Foamposite Shoes
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 04:02:18
Nike Air Max 1 Schoenen
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 03:58:34
Prodotti Adidas Nizza
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 03:52:24
Chaussures de Nike Air Vortex
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 03:47:18
Marlboro Cigarettes Online thirty minutes
Last post by sellcigarette in Paintball talk on Aug 23, 2021 at 09:36:02
