Visitors: 57
Total: 57
Forums › Marker Talk › Problem/Tech forum :: Archives › PDS oddity :: Archived
PDS oddity
shady_lizard
PostPosted: Tue Oct 12, 2004 9:22 pm    Post subject: PDS oddity
any idea why PDS works without air, but not with air? [dry firing] it also works with just a ram gauge.....once you add the bolt, it just keeps going
could it be a low battery? or just PDS gone screwy?
PostPosted: Tue Oct 12, 2004 10:43 pm    Post subject:
What board are you using?
Sounds almost like your after-eye delay is set too low on a Chaos board - the eyes are seeing your bolt as the next ball, so it in effect cancels any advantage that PDS might give you.
shady_lizard
PostPosted: Tue Oct 12, 2004 10:47 pm    Post subject:
Chaos chip on a LCD board 4ms eye delay. i don't think that's it because it does it no matter what speed i shoot.
PostPosted: Tue Oct 12, 2004 10:55 pm    Post subject:
Definitely sounds like something's odd with the board... do you have the stock board to test with?
shady_lizard
PostPosted: Tue Oct 12, 2004 11:27 pm    Post subject:
its on a B2k2 LCD stock board with Chaos chip
stock chip = no PDS
PostPosted: Wed Oct 13, 2004 6:11 am    Post subject:
Okay.. do you have any other board to test with? If you're certain that PDS *is* working, just not when the bolt's in use, then... logic would dictate that the problem has something ot do with the bolt - perhaps there's a problem with the chip.
Are you 100% sure it stops working only when you're using the bolt? i.e. have you absolutely eliminated all other potential errors, like a faulty sensor, busted/pinched wire, old/weak battery..?
shady_lizard
PostPosted: Wed Oct 13, 2004 10:42 am    Post subject:
it does not shoot when the bolt does not move, but is not blocking the sensors, like it should. once the bolt is attached to the ram and starts moving, it appears PDS does not work because it still shoots when there is nothing in the breach and the bolt is cocked. as far as i can tell, all of the wires check out and the battery definitely is new, unless my voltmeter is lying to me Razz
PostPosted: Wed Oct 13, 2004 2:45 pm    Post subject:
Something's not right here.
If it won't shoot when the bolt isn't in there.. how would you EVER get the first shot off?
I still think you need to put air on this thing and run it in dryfire mode, and again with paint.
