Overall: 7911
Members: 1
Visitors: 135
Total: 136
 Members:
01: Ev0_ST205 > Forums
109: Home
121: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › '04 BKO breakin paint like crazy :: Archived
BKOpyro
PostPosted: Sun Nov 07, 2004 11:51 am    Post subject: '04 BKO breakin paint like crazy
Please help i'm loosing my mind. I have an '04 BKO that breaks paint in the breach / barrel. I am using a halo with compressed air. My hpa is set at ~310psi and my lpr is set at the lowest it can be without drop. I have tried different paint, new batteries, a different barrel, various detent mods all with no improvement. I will shoot 1 ball at a time (1 per second) until i get a break, I then disassemble and inspect. Most of the time there will be little, if any paint on the bolt and breach. The bulk of the paint starts in the barrel and most of the time there is a 'streak' of paint running the length of the barrel. All of the paint that I have used has passed the 'blow test' so its not like i'm shooting paint that is too big. The streak of paint that i reffered to runs along the bottom, side of the barrel, opposite the detent. As far as frequency goes, I can not shoot ten balls without a break. Any help you can offer is appreciated!! THANKS!!!
Big_Mac
PostPosted: Sun Nov 07, 2004 2:50 pm    Post subject:
check for burrs? sounds like you've looked/remedied everything else
Stupidity Kills
BKOpyro
PostPosted: Sun Nov 07, 2004 4:23 pm    Post subject:
I have checked for burrs, it seems clean. Thanks for the reply Big_Mac!! Please keep 'em comin!
BKO_Ballistics03
PostPosted: Sun Nov 07, 2004 4:43 pm    Post subject:
What kind of detents have you been using? Maybe theres a piece of metal stickin out thats choppin a ball? Or if the detents youve been using are to stiff theve been known to slice a ball. Try a rubber washer.
HK Affiliate
Front player for hire
Proud member of the anti-pants revolution
Gun setup:
Black 2k4 BKO
Cp 2 piece barrel
CP Rail
Halo Reloader B
Crossfire LP tank
Big_Mac
PostPosted: Mon Nov 08, 2004 7:38 am    Post subject:
It would be pretty odd, but I think you might have a barrel fit problem...like the threads aren't aligned with the body correctly. Can you put a finger through the feedneck and feel along the joint where the barrel meets the body (on the inside) and see if there's some kind of mismatch? I'm really reaching here!
Stupidity Kills
soap_shoes
PostPosted: Thu Nov 11, 2004 11:32 am    Post subject:
uhhhhhh ive always noticed in my 2k3 bko that, if i take the bolt out but keep the barrel in, and i look through the gun from the bolt side, i can clearly see where the barrel meets the body
i dont know if thats normal, just my input
2k3 silver bko[]male palmers stabe[]halo b[]vapor 2 bolt[]red valve[]microswitch screw mod.[]pds
View user's profile Send e-mail AIM Address MSN Messenger Yahoo Messenger
melo
PostPosted: Thu Nov 11, 2004 2:53 pm    Post subject:
what hopper r you useing
none
PostPosted: Sun Nov 21, 2004 12:45 pm    Post subject:
halo b like he said
