Menu: |
User Info |
Donations |
Donate and suport ICDO! |
Forums › Marker Talk › Problem/Tech forum :: Archives › Reg disasembly :: Archived |
Reg disasembly Have a problem with your marker? Ask here
Author |
Message |
Sportsman Novice
Posted: Tue Apr 12, 2005 8:09 pm Post subject: Reg disasembly |
I have come to the conclusion that my problem is my reg!! I took the reg off of my gun and now i cannot open the reg!! its almost like theres loctite in there or somtthing! Its a real pain in A$$!!! Ive tried an adjustable wrench and surgical gloves and the gloves ripped!! Man its stuck together good!! Need help how do i disconnect the reg??? remember its off the gun already!!
thanks for your help in advance!!
Back to top |
dogred Rookie
Posted: Wed Apr 13, 2005 3:20 am Post subject: |
What you need is some heat, remember to remove the orings!!!
Back to top |
CJLOVI Pro Baller
Joined: Apr 07, 2005 Posts: 723 Location: Connecticut http://carl815.tripod.com/
Posted: Wed Apr 13, 2005 3:24 am Post subject: |
Two rubber strap wrenches
Back to top |
Sportsman Novice
Posted: Wed Apr 13, 2005 9:51 am Post subject: |
okay thanks guys but im not quite sure where to put the wrenches!! I have clamps at skool so i will use those also!! Im wondering how many pieces it will come into!! Like the actual body! Also were should i place the wrenches b/c on my reg theres only one place to put a wrench and the rest is perfectly circular! THANKS
Back to top |
L8P Rookie
Posted: Thu Apr 14, 2005 6:08 pm Post subject: REG |
Sportsman if the flats are the bottom,it unscews CCW, where the spring,reg cup and seal are. Next cylinder unscrews CCW from the top cylinder using two strap wrenches(as stated above), where the piston, spring and ball are. The pointed setscrew adjusts the ball which tensions the spring. Lightly lube all contact surfaces. Hope that helps. L8P
Back to top |
Sportsman Novice
Posted: Fri Apr 15, 2005 3:01 pm Post subject: |
thanks for all the help! I took the reg apart already lubed very nicely! I lubed it any way! The problem is the piston cover OR the thing that the piston hits in order for air to go through!! This is not letting air through! Called ICD and they said send it in so that is what im going to do!
THANKS FOR ALL WHO HELPED!!
Back to top |
Photo Gallery Pics... |
Forums scroll Last posts |
Last 10 Forum Messages |
