Visitors: 34
Total: 34
27: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › bolt jam :: Archived
bolt jam
Pete
PostPosted: Sun Nov 02, 2003 11:53 am    Post subject: bolt jam
has your bolt ever jammed up front and leaks all your nitro in like 10 seconds. well mine has and i was wondering how you stop this problem.
PostPosted: Sun Nov 02, 2003 10:23 pm    Post subject:
your bolt "jam" is when you chop paint and a piece of the shell wedges in between the bolt and chamber causing it to stay in the open position. The only way to get rid of this is to get rid of chopping by making sure you dont have blow back, get sp mod, get pds, get faster hopper. PDS and sp are expensive and you have to send in your gun, try a vapor bolt and a halo b. That may solve your chopping problem.
Pete
PostPosted: Mon Nov 03, 2003 2:22 pm    Post subject:
belive it or not, it gets stuck up in the open position w/o paint breaking so i really don't know what to do. i was thinking that my bolt was swelling up.
dval
PostPosted: Mon Nov 03, 2003 2:35 pm    Post subject:
first the sp mod is not exspensive, it cost 55 dollars and you dont have to send your marker, just the ram, i pay that for acase of paint...second is your bolt returning back completely when not gassed up? if you pull push it forward does it return completely?
PostPosted: Mon Nov 03, 2003 2:40 pm    Post subject:
your bolt might be swollen. Check your detents make sure the o ring isnt like sticking out more than it should be. If thats fine you will have to take everything apart, make sure there is nothing behind the valve, check if your ram is bent, check for shell fragments, etc.
Gibson
PostPosted: Wed Nov 05, 2003 2:46 pm    Post subject: chop
try backing out the 2 allen skrews at the back of the gun, that hold the ram housing.. just loosen them a little bit
Black 2k3 BKO, sp mod, zenitram asa, zenitram valve, micro rock lpr, sidewinder hpr, vapor bolt, mighty max, bizerk barrel system (owns) blue led :p, crossfire 68/3k, evo w/ zboard.
View user's profile Send e-mail Visit poster's website AIM Address Yahoo Messenger
rick1000
PostPosted: Wed Nov 05, 2003 9:35 pm    Post subject:
Are you using the Freak w/ an insert smaller than 689. or any other barrel system that uses inserts? My brother's bolt jams in anything smaller than the 689 diameter sleeve. If this is the case my brother took a file and put an ever so slight 45 degree angle on the bolt to prevent the sticking
funkymonkey07
PostPosted: Thu Nov 06, 2003 3:36 pm    Post subject:
i had this problem too when i first got my BKO it made me so freaking mad i couldnt play w/ it becasue i didnt know how to slove the prob. till i got home. but my probem was the ram was EXTREMLY dirty. all i had to do was take the ram out and clean the ram shaft and relube everything again and then it worked fine.
hope this helps if u havnt already fixed it.
