Visitors: 63
Total: 63
Forums › Marker Talk › Problem/Tech forum :: Archives › Intellifeed BKO :: Archived
Intellifeed BKO
Huge
PostPosted: Mon Nov 03, 2003 8:27 pm    Post subject:
The mag design setup for intellifeed does not disable the eye as has been stated here several times. It taps into the eye's output which is effectively the x-board's input which in turn tells the board to allow the batteries to juice the motor. The input signal from the eye does not run at 12v from what I can tell, the only 12v signal running in the revvy is from the batteries through the voltage regulator directly to the motor. The rest of the board is essentially the same as the 9v version, so you're not getting 12volts running through the rest of the circuitry.
JustinGB
PostPosted: Mon Nov 03, 2003 10:14 pm    Post subject:
i believe there was a tech article on www.obdo.net about this. btw i have no clue wats goin here, just tryin to help
View user's profile AIM Address MSN Messenger Yahoo Messenger
Nator187
PostPosted: Tue Nov 04, 2003 4:03 pm    Post subject:
Huge wrote:
The mag design setup for intellifeed does not disable the eye as has been stated here several times. ???Who said my design disables the eye, it doesn't???It taps into the eye's output which is effectively the x-board's input which in turn tells the board to allow the batteries to juice the motor. The input signal from the eye does not run at 12v from what I can tell, the only 12v signal running in the revvy is from the batteries through the voltage regulator directly to the motor. The rest of the board is essentially the same as the 9v version, so you're not getting 12volts running through the rest of the circuitry.If you read my Diagram you notice that the setup to activate the servo is the exact same concept that the AGD people do. The problem with the AGD intellifeed is that the rev will only intellifeed when the switch that you install is depressed. Think about it...
How long does it take you to pull the trigger???? .005 Of a second??? That's how long your intellifeed spins. What good does that do????
My design not only intellifeed when you pull the trigger but it will spin the servo at least a full rotation ever time you shoot. Along with that the normal hopper functions still work with or without the intellifeed plugged in.
www.shootpaint.com www.RedzComfort.com www.Icdpaintball.com www.NitroDuck.com www.BushmasterSource.com
View user's profile Send e-mail Visit poster's website ICQ Number AIM Address
