Visitors: 74
Total: 74
67: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Pds wont work :: Archived
Pds wont work
Koval15
PostPosted: Sun Aug 21, 2005 4:15 pm    Post subject: Pds wont work
OK so i went to my field today at it turned out my pds doesnt work. Well i found out that a wire got disconnected from my pds on/off switch. Well when i hold the wire in the right spot and push the trigger the noid still clicks. I changed the battery so that isnt the problem and my gun does work just not pds. What else could be my problem or will the switch not work til i soder (sp) it on?
OHS_Pyro89
PostPosted: Sun Aug 21, 2005 4:50 pm    Post subject:
Try resoldering it. If that works then your good to go.
If it doesnt, it may be that your baord isnt plugged allt he way in or there are loose pins in the molex.
Also, inspect eyes and make sure they arent disconnected. Clean them also.
Koval15
PostPosted: Sun Aug 21, 2005 5:29 pm    Post subject:
found out that a yellow wire was loose on both the eye and the switch which came off of both.
