Visitors: 81
Total: 81
01: Home
79: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › 2k4 bko not shooting over 260 fps :: Archived
Go to page Previous  1, 2, 3
TheArtist
PostPosted: Thu Sep 29, 2005 7:05 am    Post subject:
The one for the LPR and HPR should be the same. The one on the valve has about the same OD, larger hole in the middle, and alot taller, over 1/16th of an inch. Find your nearest ICD tech and get new reg seals and see if that helps. There are also some mods I've done to increase air flow.
Painting kids is just a hobby<br />urbanwarfare1.com
TheArtist
PostPosted: Thu Sep 29, 2005 7:12 am    Post subject:
Make sure you put the valve in the right way, and that the set screw is tight. It takes a process of elimination, you'll get it.
strategy
PostPosted: Thu Sep 29, 2005 1:02 pm    Post subject:
Thanks a lot.
Ya im about 99% sure that the LPR seal is not the right one.
Where can I find these mods to improve airflow?
strategy
PostPosted: Fri Sep 30, 2005 4:36 pm    Post subject:
Ok bad news. I thought the one on the LPR was the wrong one. However the hole in the seal is the same size as the hole in the metal of the LPR right by the seal. And the hole of the one in the HPR is bigger than the hole in the metal beside it. So it looks like the one in the LPR is the correct one. This means that none of the seals are cutting off any airflow. Sooo are we back at square 1?
battosai
PostPosted: Sun Oct 02, 2005 8:40 pm    Post subject:
dear all,
i want to upgrade my Bushmaster. This is my first e-marker. it really amazing when i used it at Asia Pacific paintball champ in malaysia. Which part i must do first, second and....? where i can have it?
really need help coz i'll have my next tourney on nov.
Page 3 of 3
