Visitors: 177
Total: 177
98: Your Account
138: Home
139: Home
140: Home
146: Home
156: Home
158: Home
166: Photo Gallery
Forums › Marker Talk › Problem/Tech forum :: Archives › CHAOS V-Link Connection Problems :: Archived
mikijm
PostPosted: Mon Oct 17, 2005 7:39 pm    Post subject: CHAOS V-Link Connection Problems
Hey Guys,
I have a CHAOS Board for my '04 Gen2 Freestyle. I also got a vlink cable to aid in programming.
I have had no luck on connecting the board with my computer. In fact I have tried it on 3 computers so far and no luck. It seems to be doing something because when I try to download the settings, the light on the on/off switch goes off until it comes back and say that it cannot fin it.
Any ideas? Could the vlink cable be bad? ways to check?
Mike
ericthegreat
PostPosted: Mon Oct 24, 2005 6:08 pm    Post subject:
the software says it cant locate the board?
first make sure the plug is in the board right.
then make sure your battery isnt low.
after that it may be the settings on your computer. i had problems with one of my computers. in bois the port has to be set to two-way communicate, some computers defult to outgoing only.
if that dosent work then you need to test the cable and make sure the connections in it are good.
mikijm
PostPosted: Sat Oct 29, 2005 6:55 am    Post subject:
- Tried pluggin the cable in both ways with no luck.
- Tried 3 brand new batteries out of the package.
- Have tried it on 4 different computers now with no luck.
- What would the easiest way to test the cable?
Mike
ericthegreat
PostPosted: Tue Nov 01, 2005 12:42 am    Post subject:
continuity test the connections in the cable. you will need a multitester or a fuse tester or somthing along those lines.
if thats not it then its the bois setting for the port on your computer/s
wargamespb
PostPosted: Sat Nov 12, 2005 7:36 pm    Post subject:
So now we should go into the BIOS??
I'm sure this is a bug that Vaporworks could address w/out having to go into our BIOS?
