Visitors: 123
Total: 123
62: Home
92: Home
94: Home
99: Your Account
122: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Reg problem :: Archived
Reg problem
killas1mo
PostPosted: Sun Oct 30, 2005 9:27 pm    Post subject: Reg problem
Hey,
Im having a problem with my stock reg on my B2K4 STD. The HPR will not let gas pass through into the gun. I took it apart (split the upper and lower half) and air will pass through the lower half but not the top. Ive read the other threads in here and it seems people have similar problems but most people just tell them to "buy a Bob Long torpedo". Any help *Fixing* this problem would be great. Oh also this happend while I was playing. Nothing was taken apart and no settings were changed in between when it worked and when it just stopped working.
View user's profile MSN Messenger
killas1mo
PostPosted: Tue Nov 01, 2005 12:38 am    Post subject:
Id really like to get some help with this......Anyone??
Please............
ericthegreat
for some reason the pistion binds up, i think.
i had one that did the same thing. i have no clue what causes it. its a shitty reg design. like youve been reading, buy a new reg.
Deleted_User_3312
Banned
PostPosted: Tue Nov 01, 2005 7:10 am    Post subject:
If you got some, get some super lube, lube gel, or dow33; and lube the piston. Also, use dow55, super lube, or ICD lube and lube your other seals and o-rings. Turn the pressure down low on the HPR and gas the gun up. Then slowly air I up. By now it should be working correctly with no flaws. IF not, go back and clean the airways of the regulator with a q- tip. If it doesn’t work after that, I cant tell you what’s wrong with it.
killas1mo
PostPosted: Wed Nov 02, 2005 1:37 am    Post subject:
Thanks guys
Ill try cleaning/lubing it and see what happens!!
killas1mo
Deleted_User_3312
Banned
PostPosted: Thu Nov 03, 2005 7:36 am    Post subject:
Don’t forget to post back and let me know what happened. Hopefully my tips work out for you. Also, if the regulator doesn’t work after that, I would recommend you buy a freestyle or 03BKO stock reg. They work very well for me. Little to no drop off and I have NEVER had any spikes.
