Latest: ccffefd17
New Today: 1
New Yesterday: 1
Overall: 7907
Visitors: 91
Total: 91
55: Your Account
81: Home
Forums › General › Paintball talk :: Archives › need sum cocker help :: Archived
adriann222
PostPosted: Sat Feb 04, 2006 5:17 pm    Post subject: need sum cocker help
Hey guys, I just put my cocker back together and I was kinda fiddlin' with the timing and I don't have any paint to rapid fire or anything so I'm not sure if it's all timed right. It appears (to the naked eye) that it fires and cocks at the exact same time. But when I put a piece of paper in the feedneck it didn't pop out so there's no blowback (right?). I don't have any paint here to test it out of dial in the FPS but if there are some tests I can do here to make sure it'll be ready to go next time I go to the field I would appreciate it.
A
Spicewon
PostPosted: Sun Feb 05, 2006 10:13 am    Post subject:
You are correct in your observations, cockers do fire from a closed bolt position, when fired the air is released from the hpr through the bolt, and at the same time the lpr charges causing the cocking arm to move back toward you and cock the hammer, then the spring force brings the cocking rod, back block, cocking arm and bolt back to the closed position and the cycle restarts. The problem is to make sure that the lpr pressure is set properly and that the cocking arm is set to the correct length. The problem if it is not set correctly will be you short stroking the trigger. Try to fire it as fast as you can then give the trigger half pulls if the cocking block does not go back all the way it will not load a ball and the breech will be empty on the next shot. Good Luck.
China Injection Vials Caps
Last post by ccffefd17 in Paintball talk on Jul 17, 2018 at 01:53:36
China Handbag suppliers
Last post by ccffefd17 in Paintball talk on Jul 17, 2018 at 01:53:25
Auxiliary Equipments quotation
Last post by ccffefd17 in Paintball talk on Jul 17, 2018 at 01:53:16
Customized Snack Food Machine
Last post by ccffefd17 in Paintball talk on Jul 17, 2018 at 01:53:09
wholesale PP Honeycomb Core Panel
Last post by ccffefd17 in Paintball talk on Jul 17, 2018 at 01:52:56
Full Automatic Pocket Tissue Paper Machine manufacturers
Last post by ccffefd17 in Paintball talk on Jul 17, 2018 at 01:52:50
CNC Machining Parts suppliers
Last post by ccffefd17 in Paintball talk on Jul 17, 2018 at 01:52:39
Flamingo Drawstring Backpack manufacturers
Last post by ccffefd17 in Paintball talk on Jul 17, 2018 at 01:52:22
China Solid Wood Dining Chair Restaurant Chair suppliers
Last post by ccffefd17 in Paintball talk on Jul 17, 2018 at 01:51:58
Recessed LED Panel Lights price
Last post by ccffefd17 in Paintball talk on Jul 17, 2018 at 01:51:44
