Latest: major_movit
Overall: 7915
Visitors: 39
Total: 39
21: Home
22: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Chaos settings :: Archived
Chaos settings
rick1000
PostPosted: Mon Dec 01, 2003 3:35 pm    Post subject: Chaos settings
Hey guys I have a chaos 03 SO board and I need some help with a few things. First can I set my dwell and debouce or is this just set at unlimited firing rate? Also what are the best setups for this on a b2k3 with pds, and halo b w/z code?
Red B2k3 w/pds, Chaos 03 board, Vapor valve, Vapor bolt, Mac Dev LPR, HAlo b w/ Zcode, Full Freak w/ 12" matching red tip, 68/4500 Crossfire tank, Sidewinder Reg 05 Speed, with Arsenal board, CP Reg, Unimount, Freak Kit.
Keo
PostPosted: Mon Dec 01, 2003 6:23 pm    Post subject:
icd-owners.com/icd/mod...opic&t=545
if this thread was in the correct place it would've been found easy
rick1000
PostPosted: Mon Dec 01, 2003 6:31 pm    Post subject:
well that's fine but that thread tells me absolutley nothing about the SO board settings! I need to know if you can set any of the options on an semi-only board or is it just unlimited bps.
Keo
PostPosted: Mon Dec 01, 2003 6:39 pm    Post subject:
my bad
icd-owners.com/icd/mod...etit&lid=1
check the downloads, and faq's section, there always helpful info there
rick1000
PostPosted: Mon Dec 01, 2003 8:40 pm    Post subject:
No problem keo, thanks for the help.
play2win
PostPosted: Wed Dec 03, 2003 6:47 pm    Post subject: fast settings for Semi only NPPL Chaos Board.
settings:
20/UL, Dwell 4-6 ms, Debounce 1-5 or 5-8, 4 ms AE Delay, Drop Shot after timer.
if you don't drop the shot after the timer you will get dry fires. Debounce is up to your idea of whether it's cheating or not. Tourney level is 8.
Hope this helps. Defiance has tons of info for this if I can find the link again. There is a good explanation of the firing logic across the versions.
View user's profile Yahoo Messenger
Sangerpb
PostPosted: Wed Dec 03, 2003 7:16 pm    Post subject:
bounce is not cheating man, the pro's do it all day long.
play2win
PostPosted: Sat Dec 06, 2003 1:48 am    Post subject:
Right, and so what are steroids? The must not be cheating as well. Debounce is not true semi - therefore not NPPL legal.
play2win
PostPosted: Sat Dec 06, 2003 2:13 am    Post subject: Here is the link again that I found on Chaos modes and setti
www.pbmessage.com/foru...5#post6845
