Visitors: 134
Total: 134
104: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › 05 Freestyle not cocking right :: Archived
RecycledTeen
PostPosted: Sat Jun 17, 2006 10:53 pm    Post subject: 05 Freestyle not cocking right
I have a problem with the bolt not resetting right so I turned my regs back down and raised them back up to try to get the gun to cycle correctly, but no go. All it will do is a small "pfffft" when the bolt is back in the open position. I can turn the LPR down and the bolt will come forward so it covers the hole about 3/4's of the way and then it will fire. In this position, the bolt might move an 1/8". I can push it it back with my finger and it will "pfffft" for a couple of trigger pulls until the bolts moves forward then it will shoot air like normal. I have tried it at several different HPR and LPR settings and it still does the same thing. Another funny thing is when I degass it, the bolt retracts as if it is being turned on instead of being turned off????? Does anybody have any suggestions on what is going on?
Rick
BlueDrizzle FreeStyle, Prodigy Trigger, System X HPR, STD JDS LPR, Predator Odin Board, Redz Feedneck, CenterFlag DynaFlow 68/45K
View user's profile Send e-mail AIM Address Yahoo Messenger
RecycledTeen
PostPosted: Sun Jun 18, 2006 11:51 pm    Post subject: Re: 05 Freestyle not cocking right
Doesn't anyone have any suggestions or soloutions?
Rick
PostPosted: Mon Jun 19, 2006 12:31 am    Post subject: Re: 05 Freestyle not cocking right
Sorry, I'd help you but I'm not a Freestyle guy.
RecycledTeen
PostPosted: Tue Jun 20, 2006 12:54 am    Post subject: Re: 05 Freestyle not cocking right
I figured someone would have run across this problem before.
Rick
CJLOVI
PostPosted: Tue Jun 20, 2006 4:22 am    Post subject: Re: 05 Freestyle not cocking right
It's in your air supply! Start with your ASA. Make sure the HPR is set to 400psi. Go to BlueFork Designs and follow Gregs Reg set up instructions.
www.blueforkdesign.us/...16301.html
View user's profile Send e-mail Visit poster's website Yahoo Messenger Photo Gallery
RecycledTeen
PostPosted: Tue Jun 20, 2006 5:32 pm    Post subject: Re: 05 Freestyle not cocking right
Thanks CJLOVI, I will look into it further than I did earlier. I have already tried my Backup Crossfire and changed both my HPR and LPR to different ones in an attempt to track the problem down.
Rick
CJLOVI
PostPosted: Tue Jun 20, 2006 8:32 pm    Post subject: Re: 05 Freestyle not cocking right
One mod I did was to dremmel air channels into the stock asa pin! It's the Brass piece in the asa. I also found that there is a sweet sopt for turning the asa screw in! To far blocks the air. Not enoughNot enough air. NDZ sells a awsome asa for about $40. If ya need any help let me know! I had two 05 FS's that after I worked out the bugs shoot +-2 all day!
CJLOVI
PostPosted: Wed Jun 21, 2006 9:10 am    Post subject: Re: 05 Freestyle not cocking right
Here's a video of my Stock 05 Freestyle shooting. It has a Palmer Fatty and a JDS LPR and the modified Stock ASA.
media.putfile.com/Stoc...-Freestyle
Thats a full hopper of paint.
dyn2liv
PostPosted: Wed Jun 21, 2006 12:39 pm    Post subject: Re: 05 Freestyle not cocking right
You may want to take a look at your orings as well. If they haven't been lubed in a while they maybe getting tacky or just wore out. I just ran into this on mine. I replaced all the o-rings in the cylinder (cheap insurance) and my FS was moving like new again. New rubbers and super-lube = sexy ball slingin'.
CJLOVI
PostPosted: Wed Jun 21, 2006 1:22 pm    Post subject: Re: 05 Freestyle not cocking right
I would think that even if the o-rings are worn and soft some bolt movement would be present. Make sure your HPR is at 400psi and then try to adjust your lpr. Soft o-rings will definately hurt the performance. Using anything other than superlube will expidite the softening of the o-rings. Shocker Lube Dow 33 and Dow 55 are definately a "NO-NO."
