Latest: major_movit
Overall: 7915
Visitors: 38
Total: 38
09: News
16: Your Account
20: Your Account
26: Your Account
31: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › FPS low... :: Archived
FPS low...
jc6711
PostPosted: Thu Aug 17, 2006 4:33 pm    Post subject: FPS low...
The pressure going into the gun from the reg is 300, how high is to high for the gun. Basically what is the highest pressure the gun can take, the gun is a B2K4
B2K4-Red To Black Fade- Apachii- Dead on drop
2002 Honda XR 100r
Bushmaster> My Anti Smartparts
PostPosted: Thu Aug 17, 2006 4:40 pm    Post subject: Re: FPS low...
set your hpr to around 250psi and you should be golden
Ehumes83
PostPosted: Thu Aug 17, 2006 7:45 pm    Post subject: Re: FPS low...
are you not getting good velosity? or were you just asking about HPR pressure?
Big_Mac
PostPosted: Thu Aug 17, 2006 11:46 pm    Post subject: Re: FPS low...
the thread is "FPS Low" Smile
If you can't get proper velocity with 300psi input you have a problem. You are turning your LPR up also....right?
Stupidity Kills
Ehumes83
PostPosted: Fri Aug 18, 2006 7:03 pm    Post subject: Re: FPS low...
check to make sure your valve is in correct. the setscrew can back out and tweak the valve a little restricting the air flow
Blue '04 Bushmaster, detonator reg, CCM Feedneck, Cp barrel,psycho ballistics medium drop, PMI 3k/72ci tank, empire reloader2
jc6711
PostPosted: Sat Aug 19, 2006 12:20 pm    Post subject: Re: FPS low...
i will try that at the feild this weekend. What kinda tank do you need to run a bushy, high or low?
2002 Honda XR 100r
Ehumes83
PostPosted: Sat Aug 19, 2006 4:52 pm    Post subject: Re: FPS low...
Doesnt matter either a high or low will work.
jc6711
PostPosted: Sun Aug 20, 2006 1:14 am    Post subject: Re: FPS low...
thanks, i just needed to know because i am gunna buy a tank from my freind so i just wanted to make sure.
2002 Honda XR 100r
