Overall: 7911
Members: 1
Visitors: 80
Total: 81
 Members:
01: lexiones > Home
78: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Promaster Not Firing... :: Archived
TenaciousD
PostPosted: Mon Aug 07, 2006 1:07 pm    Post subject: Promaster Not Firing...
Hello Everyone,
I'm having some issues with my Promaster, and I was hoping someone could point me in the right direction as far as what I should check or what the problem might be...
Here's the whole story..I was playing last sunday when the Promaster started misfiring, double feeding, etc. At the time I chalked it up to bad detents or something similar, and took my spare marker out of the gear bag. (I was generalling a big game at the time, didn't have a chance to tech it right then).
So a few days later I get it out to figure out what the problem is, air it up (bolt cocks fine), and try dry firing. The marker will not fire, rather the solenoid makes a strange noise similar to a "phut phut phut" . I took both regs apart, relubed them and tried again, but still not working. I replaced the battery, still not working. Also, after 5-7 shots the HPR will "click" (HPR set to 225psi), and despite what settings the dip switches are set to, it ramps to full auto.
I'm going to take the LPR apart again tonight to check for a blockage, but other than that I'm out of ideas. Am I looking at a bad solenoid? Could it be a clogged QEV? Any ideas would be greatly appreciated.
Thanks in advance,
-Dave
PostPosted: Mon Aug 07, 2006 3:24 pm    Post subject: Re: Promaster Not Firing...
Hm. Have you tried a new battery?
Hm. Have you tried a CONFIRMED new battery? i.e. you didn't swap out with a flaky battery, did you?
What about the board.. what are you shooting? Stock?
TenaciousD
PostPosted: Mon Aug 07, 2006 4:34 pm    Post subject: Re: Promaster Not Firing...
It's very possible the battery I put in it last night had issues as well...I swapped out the old one and put in the spare I keep in my toolbox. I'll pick up a fresh one tonight and give it a try.
-D
PostPosted: Mon Aug 07, 2006 5:01 pm    Post subject: Re: Promaster Not Firing...
What about electronics? What are you shooting? Stock, Kila, 2k6 chaos, etc..?
Some of the earlier 2k6 chaos boards had flaky components (mfg's fault, not VW's); the later versions worked okay. Based on your comment about dip switches, though, I'm guessing stock or Kila.
Sounds to me like you have regs that need to be rebuilt. I ran a tourney this past weekend where a guy had a similar problem with a stock marker - the regs were questionable at best. Then again, at least his would still fire..
TenaciousD
PostPosted: Mon Aug 07, 2006 5:24 pm    Post subject: Re: Promaster Not Firing...
Sorry about that...yes I have the stock board.
I'm still getting the hang of this stuff (I'm a reformed A5 owner), so I apologize if I sound too noobish. When you say the regs need to be rebuilt, you mean a complete disassembly / relube / etc?
UPDATE: I replaced the battery with a brand new one, and that resolved the ramping issue I was having. Also, I tried turning up the LPR to get the Solenoid to vent (to verify airflow to the solenoid), when I did that I heard a loud pop and the gun was able to be fired. I have no idea what happened..blockage?!?!
The only remaining issue is the HPR "clicking". Watching the needle on the HPR gauge I can see that the pressure starts at 225 then slowly drops to 175 and "clicks" back up to 225. I'm guessing this is an HPR issue? No leaks were detected.
-D
-D
dyn2liv
PostPosted: Thu Sep 14, 2006 7:22 am    Post subject: Re: Promaster Not Firing...
-> That isn't your HPR doing that. Well it is is and it isn't.
-> You have a leak somewhere that is draining off HPR air and the HPR is just opening to refill the chamber.
-> All air starts from the HP reg. Air then goes to the LPR, from LPR to the Solenoid, from the solenoid to the ram. Air also fills the chamber in front of your valve.
-> Check simple leaks 1st; LPR & o-rings, HPR joints, open clamshell & check valve lock screw, check all hosed connections and check the back of the ram housing cap. Do these checks with a 50/50 solution of soap & water, use an eye dropper to apply, spray bottles tend to make a mess. (Just remember not to drown everything, it is after all electrical and will fry/ short out)
-> Hope this helps.
PostPosted: Thu Sep 14, 2006 10:10 am    Post subject: Re: Promaster Not Firing...
And FYI.. A little birdy told me that jacking the stock PM board in backwards can in many cases FRY the board...
I suspect that's what happened to mine, since I had it all disassembled and wasn't paying attention to how the harness header was oriented.. Sad
TheArtist
PostPosted: Thu Sep 14, 2006 2:25 pm    Post subject: Re: Promaster Not Firing...
check to see if it is the one with a double o-ring. I've had nothing but trouble with them. I changed them to the single one and no problems.
Last post by R2Ranger in Bushmaster General talk on Feb 22, 2019 at 22:00:55
