Visitors: 153
Total: 153
66: Your Account
77: Home
153: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › 04 BKO lpr acting funny. :: Archived
mc-hammer
PostPosted: Sat Jul 22, 2006 11:01 pm    Post subject: 04 BKO lpr acting funny.
After shooting about a case of paint through my bko I"ll start to get a leak from the noid as if the lpr is over pressurizing it. So I turn the lpr down a little more and it stops leaking. I've had to turn down my lpr twice after each case of paint. My hpr is set at 250 and lpr is set all the way till it leaks and back till it stops leaking. Any ideas of what it could be or what I could do to stop it? Confused
Pntbll500
PostPosted: Sat Jul 22, 2006 11:10 pm    Post subject: Re: 04 BKO lpr acting funny.
tighten the noid what mine seems to do is come loose after a while
mc-hammer
PostPosted: Sat Jul 22, 2006 11:44 pm    Post subject: Re: 04 BKO lpr acting funny.
Forgot to say I already did that.
Pntbll500
PostPosted: Sat Jul 22, 2006 11:53 pm    Post subject: Re: 04 BKO lpr acting funny.
call ICD then you might've damaged the gasket or the noid itself it might just be an oring somewhere
mc-hammer
PostPosted: Sun Jul 23, 2006 12:19 am    Post subject: Re: 04 BKO lpr acting funny.
Ok, Thanks for the help.
PostPosted: Sun Jul 23, 2006 4:22 am    Post subject: Re: 04 BKO lpr acting funny.
Could also be creeping from your LPR. If you take apart your LPR, clean then re-lube it. That may solve your problem.
Norbinc
PostPosted: Thu Sep 14, 2006 9:04 pm    Post subject: Re: 04 BKO lpr acting funny.
Had the same prob on B2K4 (blk 1) w/chaos mini roc hpr & stock lpr loaned it out (never again) Disassembled entire marker reassemed at frnt & worked towards back even took apart noid,manifold wiped clean lubed still leaked,took apart lpr replaced oring & swapped out spring that seemed to do it not exactly sure why but it work fine now ????
Take you kids paintballing its the only time you can shoot them and get away with it.
Silver Karnivor:
s1083.photobucket.com/...030224.jpg
dyn2liv
PostPosted: Sat Sep 16, 2006 7:23 pm    Post subject: Re: 04 BKO lpr acting funny.
Yeah, what he said...
And while it is apart icpect the cup seal real close. Put it back in facing the opposite way and see if that helps. There may be a defect in it you cannot see.
