Visitors: 177
Total: 177
47: Your Account
54: Home
77: Home
100: Your Account
123: Home
157: Home
165: Photo Gallery
170: Home
174: Photo Gallery
Forums › Marker Talk › Problem/Tech forum :: Archives › just got gun back from vapor...more screwed than ever :: Archived
b3n
PostPosted: Sun Sep 28, 2003 2:29 am    Post subject:
Hey, if I were you, I wouldn't tinker w/ anything yet. If it's been vaporized, Goldie, as a ICD tech, has a warranty on it. So ask him and he'll help you out.
Goldie
PostPosted: Sun Sep 28, 2003 4:48 pm    Post subject:
Ok, did you do ANYTHING to the gun when you got it? Adjust the regs or anything even minor?
Back your HPR all the way out and see what happens. Your gauge SHOULD go down.
Try cleaning it. When it comes to aftermarket regs I don't actually do anything to them or do any sort of warranty on them. I'll do what I can to help you, but if you do find a problem with your reg, then you'll probably need to contact bob long directly.
And your cocking knob... .Your talking about you had the 2 piece style with the colored knob on top? And it broke right at the bottom of the colored piece? If so, that's a pretty common problem. I snapped probably 5 of those things.
Let's cocentrate on the HPR problem then adjusting the LPR is cake. We'll get you taken care of.
icdown
PostPosted: Sun Sep 28, 2003 5:44 pm    Post subject:
ok...
back both or your regs all the way out.
gas it up and set your hpr to 200psi
if your lpr is backed all thw ay out, the marker shouldn't cock and the solenoid shouldn't leak.
You can slowly screw in your lpr until it cocks, then give it another small twist. You may have your solenoid over pressurized.
Do you have the stock reg or rock lpr?
Sangerpb
PostPosted: Wed Oct 01, 2003 7:27 pm    Post subject:
that sux man, I saw a noid on ebay for like 20 or 30 bux the other day, I'm pretty sure nobody bid on it, check the past auctions within one week for solonoid sp?. Maybe you can get him to sell it to you for cheap!
Keo
PostPosted: Thu Oct 09, 2003 9:23 pm    Post subject:
okay, air is leaking from the grip frame, but will the gun cylce? if so all you might need is a gasket, check your gasket, i blew plenty of gasket as a noob, there $5 from either Paintball Kingdom or Tanturm, another thing, it use the same gasket as the Impulse so your local store might have one.
Keo
PostPosted: Sat Oct 11, 2003 10:55 pm    Post subject:
yes
Goldie
PostPosted: Sun Oct 12, 2003 7:54 am    Post subject:
Does the noid leak from the side or the back? Take the tray off and find out and we can tell you whether it's blown or just out of adjustment.
Goldie
PostPosted: Sun Oct 12, 2003 1:36 pm    Post subject:
have you checked the screws on the noid to see if they're tight?
madgoat33
PostPosted: Sat Nov 01, 2003 9:54 pm    Post subject:
I highly doubt you blew your noid. Sounds like its just bleeding off extra pressure...clean and lube the LPR then turn it way down to the point where the gun won't cock then screw it in til it cocks then another 1/4-1/2 turn.
These are just some examples
