Latest: Fadomtg77
Overall: 7926
Visitors: 130
Total: 130
105: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › Blowback/around? :: Archived
Blowback/around?
vincib
PostPosted: Fri Dec 19, 2003 12:48 pm    Post subject: Blowback/around?
I have noticed when I rapid fire a chop will normally occur.But there is goobs of paint gettin into the feedneck of the marker and my halo even pieces and splatter of shells into the body of the hopper. Is this explosive chopping or some form of blowback that is going around my bolt and up?
2k4 Viking
2k3BKO,J&J Edge Kit,14"CP,Lapco Bigshot,Sidewinder/McDev 300psi guage/Mitey Max,Vapor Valve/Mods/Vapor bolt
2k3 Choas Board,Zenitram ASA w/microrock
vincib
PostPosted: Fri Dec 19, 2003 1:02 pm    Post subject:
I held my marker up looking into the front without the barrel on with the bolt in the see if there was a gap around the top... My God I could watch a movie through there.
2k4 Viking
JustinGB
PostPosted: Fri Dec 19, 2003 1:27 pm    Post subject:
vapor bolt. and ho'ws that edge kit work for you?
Quote::
Originally posted by Harbinger[TG]
ask goldie, at one time i was gonna have him flatline my bushy
My Feedback!
View user's profile AIM Address MSN Messenger Yahoo Messenger
vincib
PostPosted: Fri Dec 19, 2003 1:42 pm    Post subject:
I'm liking the edge kit, I have four backs and three fronts, wholesale on it was like $160 bucks. The green for the fronts they use matches the green BKO perfectly and with the black backs it looks cool.I'll post a pic when i get a moment over the weekend.
2k4 Viking
Bko_monkey
PostPosted: Fri Dec 19, 2003 6:08 pm    Post subject:
what year BKO you got? if its 2k3since you got a halo(force feed) it could be double feeding.
NickCaporal
PostPosted: Sat Dec 20, 2003 7:47 am    Post subject:
no, double feeding wouldn't cause that explosive type chopping, thats blowback. I ust to have explosive chopping until I got a vapor bolt.
RooR
vincib
PostPosted: Sat Dec 20, 2003 7:57 am    Post subject:
It's a 2k3 model but the reason I would discount double feeding atleast partially for this issue is that when that has happen I've seen two balls come out of the barrel. I think that gap aroung the top of the bolt explains alot. Double feeding has happened a few times but hasn't been a problem. Would be nice to do away with it all together (I've done the macroline mod)
but its a trade off at this point , the speed and availability of balls from the halo and occassional double feed or out shooting a 12v.
2k4 Viking
vincib
PostPosted: Mon Dec 22, 2003 3:13 pm    Post subject:
Got the Vapor bolt in and put a Halo load through it , no chops. I can still see a bit of light around the bolt, should those orings be lubed with something, dow 55?
Now I do hear and leak coming from the selonoid. I had leak from there earlier and put gasket sealant between the selonoid and ram housing and it fixed the leak. This leak has the characteristics of an overpressure as when you exceed the 125psi from the lpr. When I fire a shot or two it seems to null the hissing for a while and then it will come back and I fire a shot or two or make a slight adjustment to the lpr and it quits again. Now keep in mind that the lpr is set well below the 125psi. Could the lpr be spiking? Any thoughts?
2k4 Viking
chord509
PostPosted: Mon Dec 22, 2003 4:59 pm    Post subject:
Yes, lube the orings. Firing them dry could do some "interesting" things to them. Did you try tightening the solenoid screws?
"Then Jesus said, ‘Father, forgive them; for they do not know what they are doing.’" -Luke 23:34
CPPA Member #1485
View user's profile Visit poster's website ICQ Number AIM Address MSN Messenger Yahoo Messenger
Dennis
PostPosted: Sun Dec 28, 2003 2:01 pm    Post subject:
what do you lube the orings with?
Skechers Flex Appeal a few
Last post by Fadomtg77 in ICD Mech Markers on Nov 30, 2020 at 05:43:04
Nike VaporMax 360 posiblemente
Last post by Fadomtg77 in Paintball talk on Nov 30, 2020 at 05:39:11
adidas tubular x soldes
Last post by Fadomtg77 in Off Topic on Nov 30, 2020 at 05:34:17
puma suede femme noir
Last post by Fadomtg77 in Calendar of Events on Nov 30, 2020 at 05:30:04
Mike Tomlin implies there is a trong possibilitythe Steelers
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:45:00
Packers stay on offense, add RB A.J. Dillon
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:44:39
For 2nd straight season, Seahawks offense struggling to fly
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:44:12
Chiefs welcome fresh/outdated faces inside of Allen
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:43:58
Run defense issues highlight total breakdown for Saints
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:43:15
Pitch and catch: Round 2 of NFL draft heavy on receivers
Last post by Osweiler in Off Topic on Nov 26, 2020 at 03:42:37
